Rear Caliper pins seized up - Dealer says it's not covered...
Hey there - quick question.. is the rear Caliper seize up issue covered under the 70,000 mile power train warranty?
I'm out of the regular warranty and trying to change my rear brake pads... of course the things are seized like no other and lexus is telling me "sorry Man not covered"..
While Lexus got a lot of things right on this car......tiny stuff like this really makes me hate the car.
I got the same problem as you a while ago, and the dealer said that is not covered under powertrain warranty too. Also they refused to let me pick up my car unless is towed, "because of safety issues". FML, cost me 800 bucks.
Ps. I'm up in Canada, Idk if it make a difference, GL
dude i went to replace the pads the other day in the rear n my driver side rear's pin is seized up as well ...
waiting to get some funds to replace the caliper
Warm up the caliper with a Torch, it will expand the caliper bore, the Pin will break free from its "seized" state, and you can then clean out the hole, re-lube and re-assemble as necessary.
Calipers like state above are not Power train.
I work with stuck calipers at work ALL the time, easy to free-them up... just have to use a torch...
Good luck.
Caliper replacement is not necessary.
Good luck.
