2008 IS 250 RWD Engine Noise - Video
Hey all,
I just bought this car CPO about 2 months ago and I've noticed an engine noise, prior to the engine fully heating up.
http://www.youtube.com/watch?v=KHCMI...ature=youtu.be
It's more prevalent at the beginning. The dealer said it was normal when I took it in to have it looked at. Thoughts? I'm making sure to put Shell 91 into it, so I don't think it's a knock.
You have to turn it up a lot (the video and your speakers) to hear it. Sorry about that.
I hear it... sounds almost like a diesel for the first few seconds.
I can tell you that my car does NOT make that noise. The valve tapping is noisy, but completely different sound.
EDIT - Have you/dealership checked heat shields for vibration. I had a similar issue on a previous car I owned.
On the car I had this issue with, I was able to narrow it down to a general area, and the dealership found the defective heat-shield. I say defective because they tightened it first, and the problem continued. They ended up ordering a new heat-shield, and that took care of it. The sound was a little different than what I'm hearing in the video. Mine definitely didn't sound like a rattle though, and would change pitch when I revved. It would last for 10-15 seconds at start-up, then disappear.
Might be worth asking about. Good Luck!
The offender on my car was a heat-shield just behind the front bumper, before of the front axle. Had to remove a plastic under-tray to gain access. This was not a Lexus though, so location is just a reference.
I was surprised when the dealership blamed the heat-shield, too. I thought they were full of it until they ordered the replacement, and viola all gone.
They are beneath the engine, around the cat, etc...
AntzCro
03-16-15 06:46 PM
