DIY: 2011+ MY LED Headlight Installation ("How To")
#151
Just installed the 2012MY LED Headlights Loaded from Sewell and these are my questions:
1.) DRLs -- If i get it disabled by the dealer will it cause me to lose my high beam function also?
2.) LEDs -- are they at 100% after install with no modifications? Is there a downside to this?
3.) Bubbling defect -- Can someone explain this to me? I've looked everywhere and all I know is its bad. Does it have something to do with the LED running at 100% and the Low beam on?
4.) What color temp matches best with the LED strip for Low Beam/Fog combination
Hey aspeckt, I pretty sure when you get the DRL's disabled, it ONLY disables the DRL function. It would probably be a safety hazard if it disabled both totally. If that was the case people would just pull their fuse, like I have for the mean time, since Sewell doesn't know how to disable them!
I think the loaded ones from Sewell are 100% already when installed, but I didn't get mine from Sewell, I got mine from another dealership in Grapevine Texas. The only thing people don't like when only having it at 100% the whole time is that it kind of drowns out the Low beams. There are several DIY's to follow that show you how to wire them the correct way, and it is not hard at all. 100% when lows are off and 50% when lows are on.
#152
#153
I went ahead and just pulled the bulbs instead of the fuse. It was a lot easier for the time being. I rarely drive at night, so the high beams aren't all that much of a factor right now. I'm still in the process of finding a dealer capable of disabling the DRL's for me.
#154
And just an FYI, because I never got a straight answer from anyone, you can buy the relays and harnesses to wire up the headlights the CORRECT way, from Oreilly's. I tried Autozone to no avail.
#160
Ok so I did the conversion but I have a couple issues.
1. The led's, are they supposed to turn on automatically when you turn ignition on OR does it only turn on when you tune the parking lights on......I say this because I have that issue that when the car is on the LED's are not on but only when I turn the parking lights to the on position.
2. Also the DRL's if the dealership does not know how to turn them off will pulling the fuse have any affect in the future
Thanks....
Thanks....
#161
Thanks....
Thanks....
#164
If you tap into an ignition power source you wont have a need to have your parking lights on. I just installed a set on my sisters IS250 and I have hers working like factory.
Once Igniton is one LED's come on
Low beams ON LED's switch to 50% power.
Also her Auto Leveling work but I had to turn black out her blinking AFS light
#165
