Just finished this mod today everything works great the only thing now is that my AFS light is blinking in the car. Any way to fix this problem
Simple way to get the light to stop blinking: Pull the AFS fuse under the drivers dash. This may also disable auto leveling, not sure...I don't really care though.
So if I buy the stripped version, the only thing I would have to do differently is transfer my existing bulbs and ballasts? I have a H11 HID kit, will that work?
Im unsure because the loaded ones come with HIDs already but idk if those are D4S...
Unfortunately your current H11 kit will not work because the sockets are different. You could buy the stripped version then buy the ballasts and a set of D4S bulbs. However, I'm not sure how cost effective that would be depending on where you get the parts from.
But the only extra parts that i would need to buy for the stripped version are a set of ballasts and D4S bulbs?
Bob , because urs car doesnt come with HID, so its better for you to get the whole set of LED=ballasts and D4S bulbs and all the accessories=prevent you for keeping headache later. Black Friday is the day
But if i only need bulbs and ballasts, i can get those cheaper than the extra $500 for the fully loaded headlights
Bob save yourself a big headache and get the loaded version, the xenon control unit is expensive everywhere. one question though, Do the stripped version come with all the covers?
no it doesn't, i learned the hard way. did not come with the led portion cover which includes the led wiring and did not come with the DRL cover. the other ballast cover is transferable if you have hids already though.
Didn't come with led cover and wiring? so led strip won't work without it hmmm....
Can you please list them? need to know which exactly do i need to order them with the headlights
