DIY: 2011+ MY LED Headlight Installation ("How To")
Old 11-09-12, 11:23 PM
  #91
ISFPOWER
ISFPOWER's Avatar
Originally Posted by faisal11ir
Didn't come with led cover and wiring? so led strip won't work without it hmmm....
Can you please list them? need to know which exactly do i need to order them with the headlights
so i had to buy the following only for the stripped lights
- rear circle cover for the led (comes with wire harness that plugs in there as well) x2
-DRL circle cover x2
both of those aren't interchangeable for previous lights without LED
and make sure you pick up the relay
Old 11-30-12, 12:06 PM
  #92
i3urton
i3urton's Avatar
did this but now my headlights wont turn on do i need to reset a fuse?
Old 12-01-12, 12:46 PM
  #93
scorpionge
scorpionge's Avatar
Im going to have to buy stock hids =( as my hallogens wont work
.. [different bulb type]
Old 12-01-12, 01:44 PM
  #94
pauklius
pauklius's Avatar
Does anyone know what i would need to get the headlights working if i just bought used oem ones? If im not mistaken the sewell ones are rewired? I tried to search but couldnt really find anything on non sewell ones. Thanks for any help in advance.
Old 12-02-12, 05:16 AM
  #95
iRyan
iRyan's Avatar
1) LED connector (2)
2) Grey Caps(2)
3) Indicator Relay
4) know how to wire the plug up to get the LED at 100%
you need a few things, you need the LED connection which has the indicator plug which you can get from the dealer...you need 2 of them, you also need two grey caps to cover the bright light area, and the last thing is the indicator relay. If i can find the part numbers I'll PM you them...
Old 12-03-12, 02:47 PM
  #96
550fresh
550fresh's Avatar
How do you get the ballast out I'm trying and I can't seem to get it
Old 12-03-12, 06:51 PM
  #97
671gs
671gs's Avatar
Look on YouTube there's a vid on how to replace it..
Old 12-03-12, 06:54 PM
  #98
andrepirch
andrepirch's Avatar
Default hey i bought lights of ebay
is it the same thing or u purchased urs that all ready had all the wiring re.. dunn ...???
do i have to re wire mine i bought all the things on ur page butt got it of ebay and not swelleparts so let me know if i did something wrong thank you or if any one else can help me
phone #951-587-5080... or email at andrepirch@yahoo.com
Old 12-03-12, 07:09 PM
  #99
550fresh
550fresh's Avatar
So you have 2 heat lense up 2 get ballast off
Old 12-03-12, 07:35 PM
  #100
andrepirch
andrepirch's Avatar
hey guys any one know which wire frim the LED lights goes to to get them on or can u guys Help me and let me know if all three wires are positive or 2 only and if u gys can let me know which ones are they so i cane get this du thank you
Old 12-03-12, 07:36 PM
  #101
andrepirch
andrepirch's Avatar
i bought my lights of ebay and will be doing rewiring my self can anyone help me please thanks ...... i just need to know were the connector for the LED light goes which one is the power and which color is negative thank you
Old 12-03-12, 08:10 PM
  #102
671gs
671gs's Avatar
No you don't ..there's a other way u don't need to heat up headlights u don't have to remove lense
Old 12-03-12, 08:59 PM
  #103
550fresh
550fresh's Avatar
Do u have the link for the video that would help a lot thanks
Old 12-04-12, 08:49 AM
  #104
cyberscorp
cyberscorp's Avatar
Hey Bro, Here's another thread that might help you in terms of wiring:
1) https://www.clublexus.com/forums/is-...0-circuit.html
2) https://www.clublexus.com/forums/6327293-post51.html
3) https://www.clublexus.com/forums/7535614-post4.html
Old 12-04-12, 08:56 AM
  #105
671gs
671gs's Avatar
Here u go
Now I accept PayPal... jk
Quick Reply: DIY: 2011+ MY LED Headlight Installation ("How To")
