Guys, I need help with my 07 is350. My passenger front window was working fine and now it’s not working at all, it won't go up or down from either switch and the light of the switch keeps blinking. What can it be? Do you think that the switch itself went bad? Or can it be something else?
Thanks for your help
Did you unplug the battery or loose power anytime recently? If so your windows need to be reset by going to each door and lowering it all the way and raise it back up. Do this to each window. It should work now.
Guys, yes i changed my battery last month and i"m aware of re-setting my windows which i did. And all but that passenger front window are working fine. So it needs to be something else.
So just to confirm...since the battery change that window switch has not worked properly? Seems like you need to re-do the window calibration all-around.
