should I go from 100% to 50% bright on LEDS?
You can have the dealer turn off those yellow DRLs off. They usually don't charge for it. As for your LEDs to function as true DRLs, you need to do a little modification in wiring, or if you don't want to do any wiring mods, then just turn on your parking light and the LED strips should turn on.
How much did the dealer charge you for installation (if you don't mind sharing)?
Did you get the 2012 Sewell lights? That's what I have. Was it hard to wire 100% ignition on, 50% low beam? I really don't care if the LEDs are 100% or 50%...I just want the LEDs on 100% of the time when in AUTO mode.
So if i install the relay, does the blue wire go to pin 86? Btw I got my lights from ebay. They're not wired like the sewell headlights.
Snapkiller
05-25-19 06:49 AM
joshoowa
01-17-13 02:27 PM
