Need Help with Droid x and BT
My wife's Droid X has started not working over the Bluetooth.
The Car shows that the phone is connected and it actually calls but when I answer the Home phone she cannot hear anything and I can not hear her. It does the same thing if she calls my cell phone a IS 4s.
This phone has worked over her Lexus ISC 250 without issue until last week. She likes the Hands free operation and it is a safety issue.
Any suggestions? I have soft reset the Driod X; I have not pulled the Battery and reset the Droid.
ANY help would be suggested.
Common problem, but pull the battery. Here's my little info/tip guide on Bluetooth
BLUETOOTH TROUBLESHOOTING:
How to set-up Bluetooth; With Navigation:
We’ll use an iPhone4 for ex. Go to
- Settings
- General
- Bluetooth
- make sure bluetooth is on (slide on/off)
- Below that is "Devices" or "search device"
- On the phone, select the "hands-free" 2009 below or “Car Multi Media” 2010+ under search device. It should begin paring and prompt you for the passkey. Enter it and select "pair". It may say it's paired but not connected. If this is the case, then select "hands-free" one more time.
From the car:
- Car on/acc mode
- Info
- Telephone
- Settings
- Register phone
- it'll bring up a menu that has a passkey and looks like it's ready to pair
- Pair
Just to double check that the phone is paired to the car, from info-telephone-settings-select phone. The phone should be in the system now with a little "BT" symbol next to it.
For Non Navigation Models:
Use the push to talk switch and the voice should layout some commands. One of which is "phone set-up". Say phone set-up and continue with the voice instructions by hitting the push to talk switch and saying "yes" "pair phone" etc... Meanwhile from the bluetooth menu in your phone (probably under settings, make sure the phone is set to "discoverable mode". Once the phone is searching, "Hands Free" should show up on your phone. Select the pair button and you should be prompted with a pass key (four digits + enter) it's usually 1111 or 1212 etc...
________
Other Troubleshoots:
UPDATE YOUR SMARTPHONES:
Make sure your smartphones are turned off every now and then. They are just like a computer and need to be updated. Sometimes if a phone misses an update, the result is the Bluetooth connection unpairing with the car.
With BlackBerry’s, the most common troubleshoot is to remove the battery from the phone, blow on it and turn the phone back on. Yes it’s a PITA because BB takes forever to load, but it typically works. If this doesn't work either, you can try repairing the phone:
MY PHONE HAS BEEN PAIRED BUT NOT WORKING:
If the phone is not working (but already paired), a common troubleshoot is the bluetooth on the phone could be turned off (happens on mine from time to time). Set the phone to discoverable mode and make sure the bluetooth is set to "on". You should see the bluetooth symbol somewhere on the phones top banner.
- Settings
- General
- Bluetooth
From the car:
- Car on/acc mode
- Info
- Telephone
- Settings
- Register phone
- Pair
________
keziah23
RX - 3rd Gen (2010-2015)
15
05-23-19 01:23 PM
