Rubbing problem... need help *Pics*
Hello,
So I put on Enkei RPF1s that are 19x8.5 and 19x9.5 +42 all around. And 245/40 & 255/35.
I noticed that I was rubbing when I turn and took off the wheels to use a heat gun and fix the spots that needed it. And I fixed it and everything, but then as I was putting the wheel back on I noticed this.
This is the front passenger
![](http://i1110.photobucket.com/albums/h460/TakaPhotoartistry/z4.jpg)
![](http://i1110.photobucket.com/albums/h460/TakaPhotoartistry/z3.jpg)
Same side but idk if its rubbing this because it looks too perfect and the other side doesnt have it at all
![](http://i1110.photobucket.com/albums/h460/TakaPhotoartistry/z2.jpg)
This is the Front driver side
![](http://i1110.photobucket.com/albums/h460/TakaPhotoartistry/z1.jpg)
I put my wheels back on and felt if its touching and its not but my tire is around 1/8" away from it. My tires go past the wheel lip so it sticks out more. My wheel lip is alittle less then 1/2" away.
Is this really bad? and is it fixable? I was thinking about getting 225/35 in the front.
Hello,
If its not touching then its not rubbing. The arm never gets any closer when driving. Its like one unit with your wheel. Your wheel/tire would have to be wobbling back and fourth for it to rub which would be a sign of bad hub bearings.
pimpmobile
Suspension and Brakes
40
02-21-10 09:11 AM
