Problem after repolish my wheels lip! HELP!!!!
Old 05-12-12, 06:37 PM
starknight
starknight's Avatar
Default Problem after repolish my wheels lip! HELP!!!!
I sent my wheels to a wheelshop to have the lip re-polished. After I got them back and cleaned them, I noticed one of the wheels has black mark on the edge of the face and lip. The black parts wont go away. Anyone has this kind issue after repolish the outerlip?
I was told that they disassemble the wheel before polish but the plan was to polish the whole lip, they made a mistake and ended up just polished the outerlip. so I seriously doubt that they disassemble the wheel.
Below are two pictures kinda gives an idea what I am talking about:
Attached Thumbnails Problem after repolish my wheels lip! HELP!!!!-550961_10101073710237931_6028449_59747323_549234212_n.jpg   Problem after repolish my wheels lip! HELP!!!!-576850_10101073710926551_6028449_59747328_8276584_n.jpg
Old 05-12-12, 08:14 PM
Rikg35
Rikg35's Avatar
Why did you have to clean the wheel when you received then back? The re polished it shouldn't it be spotless?
You did not inspect the work when you picked then up?
Lesson learned.
Old 05-12-12, 08:53 PM
starknight
starknight's Avatar
i only have the shop repolished the lip, they didnt clean the face of the wheels for me
Old 05-12-12, 09:11 PM
SCWB
SCWB's Avatar
That's the mark of polishing wheel brushed over. The guy who polished your wheel might not be careful enough or he didn't cover the unpolished area with some tapes.
Old 05-12-12, 10:33 PM
starknight
starknight's Avatar
does that mean i need to get the rim powder coated?
Old 05-12-12, 11:07 PM
Vroomin350
Vroomin350's Avatar
That means you should tell this shop that you asked for your lips to be polished not pieces of the face because whoever did it didn't feel like taping the face area.
Old 05-12-12, 11:54 PM
projectdna
projectdna's Avatar
it looks like the the outer barrel wasn't removed for polishing (you should be able to tell with your 3-piece HRE's if the sealant holding the inner and outer barrels together looks brand new or not).
you'll only need to powder-coat the faces, but that requires disassembling the wheel - which as others have posted is what the wheel shop should have done.
on a related note, if this is a certain wheel refinishing shop in southern california (shop name withheld for anonymity purposes), i can vouch that i've seen at least two instances where their work got a bit "sloppy" and not quite up to their usual standards (unless their usual standards are at this level, in which case you're pretty much SOL).
Old 05-13-12, 12:28 AM
starknight
starknight's Avatar
lol....the wheel shop is in socal, I dont want to mention their name if they are going to fix this....but I can tell you that I am not a cheap guy especially these are high end wheels >.<
Old 05-13-12, 01:48 AM
SCWB
SCWB's Avatar
Which means you should send them to reputable wheel refurbish shop who knows what they are doing. Or even send them back to HRE to tear apart and do full wheel refurbish. From the pictures, your rivets look pretty rusted up as well.
Old 05-13-12, 09:19 AM
projectdna
projectdna's Avatar
if you're referring to the shop that i'm referring to (confirm this via PM?), i can tell you that they're not going to do anything for you now that they've been paid in full.
416tt
01-31-14 08:35 AM
BOOOGS
Automotive Care & Detailing
10-26-13 06:32 AM
BGG
08-20-12 12:05 AM
kino1161OL
GS - 1st Gen (1993-1997)
11-29-05 03:50 AM
Swifty
Wheels, Tires & Brakes Forum
02-01-02 12:48 PM
Quick Reply: Problem after repolish my wheels lip! HELP!!!!
