help rubbing
Old 05-13-12, 03:30 PM
trippy
trippy's Avatar
Default help rubbing
hey wsup CL
i just installed my BC coils and my tires rub on the plastic piece on top of my tires...do you guys take off the plastic when you guys drop it ??
here's a picture and yes i know its dark haha
thanks
Old 05-13-12, 05:15 PM
IS2FIFTY
IS2FIFTY's Avatar
try using a heat gun, thats what I did to mine
Old 05-13-12, 05:24 PM
iRock
iRock's Avatar
turn the flash on
Old 05-13-12, 06:04 PM
aspeckt
aspeckt's Avatar
it rubs there when you turn aggressively? or when you drive period.
Old 05-13-12, 06:35 PM
kumquatism
kumquatism's Avatar
I cut that section of the plastic off. Well, after it rubbed through most of it anyways. You still have to worry about the fender tab that's right behind it too, though.
Old 05-13-12, 09:15 PM
trippy
trippy's Avatar
does it just melt ??
Originally Posted by iRock
turn the flash on
my flash was on haha it was during the day
it rubs when i go over dips i havent turned aggressive yet
yeah ..dont kno what to do with that..
i retook the picture
Old 05-13-12, 09:34 PM
chris07is
chris07is's Avatar
dont worry about it..it happens...sooner or later you'll replace your fender liner..
Old 05-13-12, 10:20 PM
rookieIS
rookieIS's Avatar
it will rub through the liner eventually after driving for a couple days dont worry bout it
Old 05-13-12, 10:31 PM
trippy
trippy's Avatar
haha alright thanks guys !
Old 05-14-12, 08:48 AM
busdepot
busdepot's Avatar
I think everyone who's lowered their 2IS rubs. I had rubs on my wheels before I was lowered. If it's gets really bad, you may have to relocate your bumper tab.
Old 05-14-12, 10:48 AM
dyongg
dyongg's Avatar
Is the bumper tab the metal screw that keeps the bumper connected to the fender? If it is, where did you guys relocate it to? Because I think that's the only thing I'm rubbing on right now, even after raising the car a bit. It looks so ugly I wanna go lower D:
Old 05-14-12, 10:56 AM
ZeroSeVen
ZeroSeVen's Avatar
Yes that's the one.
You must relocate the front bumper tab anytime you lower your car on coils. I pushed mine inside and modified the screw just to have enough clearance for the tires.
Try the search function and type "front bumper tab" and it'll show you threads with pictures on how members did theirs
Old 05-14-12, 11:00 AM
dyongg
dyongg's Avatar
Originally Posted by ZeroSeVen
Yes that's the one.
Thanks a bunch! Didn't know what that little piece was called :/
Old 05-17-12, 09:39 AM
Gville350
Gville350's Avatar
Depending on how aggressive your offset is and how low you are will determine if you need to do the bumper tab relocation. If you are on stock wheels and OE tire specs and lowered 2.5" or less...you "should" be fine with just the plastic liner being rubbed to death. At least, this is from my own personal experience. I'm lowered 2.5" all around on BCRs and stock wheels and OE tire specs.
Enjoy the lowered goodness!
Old 05-18-12, 08:37 AM
trippy
trippy's Avatar
im lowered on bcrs also but the rubbing is ANNOYING =( im always scared 2 drive up driveways haha
Quick Reply: help rubbing
