Rolling vs cutting fenders
Old 05-17-12, 02:35 PM
kams229
kams229's Avatar
Default Rolling vs cutting fenders
What r you pros and cons with both and which do u prefer
Old 05-17-12, 04:05 PM
Sffd103
Fire Slayer
Sffd103's Avatar
I have rolled fenders because I've heard cutting them messes with the structural integrity of the rear quarter.
Old 05-17-12, 04:11 PM
B16da9
B16da9's Avatar
Your are correct sir.
Old 05-17-12, 04:23 PM
laobo979
laobo979's Avatar
I prefer roll cause with the cut if your tire sitting on the edge of them slice and dice there goes the side walls.
Old 05-17-12, 05:38 PM
projectdna
projectdna's Avatar
rolled fenders.
Old 05-17-12, 05:59 PM
KillaIS250
KillaIS250's Avatar
Roll them.
You'll avoid the structural integrity issue and any corrosion that might occur from having an exposed edge after cutting, although some people will just use touch up paint or clear coat to help prevent that. Plus you won't cut up your tires on the edge!
Old 05-17-12, 08:39 PM
JoshIS408
- - G T V I P - -
JoshIS408's Avatar
i like my fenders shaved like my g.... ill leave it at that
Old 05-17-12, 11:32 PM
CCJ22
CCJ22's Avatar
I shaved/cut and prefer shaved. I had no structural issues yet and have sealed that area from rusting with paint/clear coat.
Old 05-17-12, 11:53 PM
MyIS350G
MyIS350G's Avatar
Rolled if your wheels are not aggressive, too aggressive then shaved
Old 05-18-12, 07:06 AM
obby
obby's Avatar
i had mind roll the other day.
Old 05-18-12, 07:48 AM
MIA_LEX
MIA_LEX's Avatar
i shaved the **** outta mine 2 years ago... structural integrity is so so, nothing compared to having plastic fenders though so you should not have to worry about much. Shave in the rear for sure.... The front you could roll
Old 05-18-12, 08:14 AM
Individual
Individual's Avatar
I shaved the rears, and rolled the fronts. I shaved a little at first, and it still rubbed, then shaved all the way, and rarely rub now. It's been over a year since I shaved it, and even when I rub every once in a while, the rear quarter panel still looks flawless. It is a hassle to keep touching it up though.
Old 05-18-12, 09:05 AM
rookieIS
rookieIS's Avatar
couldnt have said it better
Old 05-19-12, 09:16 AM
Gville350
Gville350's Avatar
I've never had to roll or shave fenders before, but if you first choose to roll them and end up with needing to cut/shave them...will that be an issue?
Old 05-19-12, 09:26 AM
SCWB
SCWB's Avatar
Rolll them fenders baby!!!
Quick Reply: Rolling vs cutting fenders
