LED flasher..!!!-- not working correctly
hi guys,
I just installed my LED flasher that I bought from V-Led... blinker work but the only problem I have is when unlocking and locking.. the blinker will light up on the driver side but not the passenger side.
.. Do I have a faulty flasher? Anyone that bought LED flasher from v-led please me know if you are having the same problem..
http://www.v-leds.com/Electronic-Fla...-p4957253.html
thanks
thanks
Could be the flasher is faulty. Best way to check is to remove the flasher unit and test it again. If everything works without the flasher, then it is the flasher unit.
Are you sure that the blinker works and the lock/unlock flashing doesn't work on that side? I think that it either works or doesn't work on one side.
Was the LED bulb changed on that side? Remember that LEDs are directional about their installation. If the bulb was changed, flip it over and retest.
yeah I test everything.. I plug back into the factory flasher and it work.. blinkers work fine is just the unlock and lock is not working correctly... one side work and one side doesn't work..
