help with hids bulb
Old 05-21-12, 07:32 AM
nctuan03
nctuan03's Avatar
Default help with hids bulb
Hello, I'm not sure if anyone has this problem but my drive side oem hid bulb on 2008 IS 250 is turned on maybe 3 mins max and turn off. The color it puts out is yellow compare to white (4300K) on passenger side. I'm not sure if it's ballast or d4s bulb problem, but I'll swap the bulb first and see what happen. Does anyone have any experiences with this problem? Thanks for responding
Old 05-21-12, 07:43 AM
caseyb83
caseyb83's Avatar
Pretty sure it's just the bulb but you can pull the bulb and see if it looks burnt or not...
Old 05-21-12, 08:28 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
It is probably the bulb.
You can swap bulbs left and right and see if the problem follows the bulb, if it does, it's the bulb.
Originally Posted by Lexus HID inspection procedure (from Repair Manual)
INSPECT DISCHARGE HEADLIGHT BULB
Confirm the following items before replacing a discharge headlight bulb. If a malfunction is discovered and repaired, perform the inspection again to confirm the repair.
  • Make sure that the high voltage socket of the light control ECU and discharge headlight bulb are connected normally.
  • Make sure that there is no damage to the high voltage socket of the light control ECU or discharge headlight bulb connector.
HINT: Even if a bulb seems to turn on normally, it may not be normal. Perform all the following steps in order because an abnormal condition might otherwise not be easy to duplicate.
Prepare the vehicle: Before performing the following inspection procedure, turn off the discharge headlight bulbs for more than 10 minutes to allow them to cool down sufficiently.
HINT: Since it is necessary to find the cause of a malfunction that causes a discharge headlight bulb not to turn on, the discharge headlight bulbs should be inspected starting from a cooled off state.
  1. Turn on the discharge headlights for more than 25 minutes, and check that the bulbs illuminate normally when they are turned on.
    HINT:
    • Leave the headlights on for more than 25 minutes to stabilize the discharge headlight bulb arc tube voltage.
    • A discharge headlight bulb that has almost reached the end of its life may turn off due to a headlight control ECU fail-safe function because the arc tube voltage is high.
  2. Repeatedly turn the discharge headlights off for 15 seconds and on for 15 seconds (5 times for each). Check that the bulbs illuminate normally.
    HINT: This inspection confirms the ability of the bulbs to start when hot.
  3. Turn off the discharge headlights for 3 minutes, and then turn on the discharge headlights for 3 minutes. Check that the bulbs illuminate normally when they are turned on.
    HINT:
    • A characteristic of discharge headlight bulbs is that their starting voltage is highest when 3 minutes have elapsed after being turned off. This is the most difficult situation for discharge bulbs to start in.
    • This inspection is further confirmation of the ability of the bulbs to start when hot.
    Standard: The discharge headlight bulbs illuminate normally in all steps.
  4. Remove the discharge headlight bulb and perform a visual inspection of the arc tube.
    Standard: The inside of the arc tube is not bulging or deformed and is not clouded. However, a dull brown coloration inside the arc tube is normal.
    Text in Illustration
    • *A Normal Discharge Headlight Bulb
    • *B Discharge Headlight Bulb at End of Usable Life
    • *1 Arc Tube
    • Inside of Arc Tube
    • Distortion / Clouded Area
Jeff
350PsDMeuP
05-15-23 01:51 PM
J-Velocity
09-12-15 01:42 AM
jbone29
04-09-12 05:27 PM
dandd2
Lighting
12-09-06 03:36 PM
Quick Reply: help with hids bulb
