Plastidip Troubles
Old 05-27-12, 09:51 AM
bowenn13
bowenn13's Avatar
Default Plastidip Troubles
Alright, I don't know what went wrong during my application process but my emblems are now effed up. The plastdip didn't peel off as advertised and now I have a bunch of plastidip stuck where my emblems join my car, and I can't get it off!!!!
Anyone know of a good cleaning product to use on plastidip?
Old 05-27-12, 10:10 AM
Initial G
Initial G's Avatar
How bad is it? Any pics would help explain what happened.
How many coats did you apply?
I did mine and had no problems whatsoever and everything peeled right off as advertised. Have you tried using some warm water and soap?
Old 05-27-12, 12:59 PM
ZeroSeVen
ZeroSeVen's Avatar
Just use a toothpick to remove any remaining plasti-dip around your emblems. It should peel off easily like a dried elmer's glue.
Make sure when you do it again that you apply a thin first/base coat and follow it up with 3-4 more evenly sprayed coats. Let it dry for at least half an hour to an hour depending on the weather in between coats.
Old 05-27-12, 01:03 PM
grassmoker
grassmoker's Avatar
Dw-40 was the one i used to peel it off and it worked like a charm
Old 05-27-12, 01:07 PM
iRyan
iRyan's Avatar
That's def strange...no one ever had that problem. Did u let each coat dry before applying more...
You can use rubbing alcohol to get it off...it works
Old 05-27-12, 01:59 PM
slimjimtel
slimjimtel's Avatar
Plasti dip is for Hondas...WHY would you even think about using this on a Lexus? The stuff is junk and looks mickey mouse.
Old 05-27-12, 05:58 PM
bowenn13
bowenn13's Avatar
Just borrowed my friend's... This stuff is worth it's weight in gold! Once I sprayed it on, all the plastidip came off with ease. I think I should leave the coat on longer this time... Last time, I waited 15 min intervals between sprays but I think I'll try 45 this time. Wish me luck!
Old 05-27-12, 06:46 PM
2soonJR
2soonJR's Avatar
I don't get it? :/ why is plasti dip for Hondas? Why can't Lexus have it? It's you're car do as you please
Old 05-27-12, 08:35 PM
Initial G
Initial G's Avatar
I don't get it either. It's your car, do what you please. To each his own.
But I've seen plasti dip used on BMW and Infiniti forums and everything has turned out great.
Old 05-27-12, 09:19 PM
grassmoker
grassmoker's Avatar
Nice brotha! I told u so!! Hehe
Old 05-27-12, 09:40 PM
bowenn13
bowenn13's Avatar
Thank you x100!!! If not for your advice, I'd still be there with my toothpick trying to scratch off all the left over plasti dip haha.
I just finished plastidip attempt #2, worked perfectly this time! I definetely didn't spray enough coats or wait long between each coat the first time, because the 2nd time around the stuff peeled off just as advertised.
Old 05-28-12, 12:34 AM
MashinA
MashinA's Avatar
plastidip is cool for a temporary solution but if you can def paint or powder coat.
Old 05-28-12, 04:31 AM
slimjimtel
slimjimtel's Avatar
Plasti dip looks cheap, doesn't clean up well and is just ugly. Has no business being used on a Lexus.
If you want black emblems, go to Sewell and get the back Pearl.
Old 05-28-12, 05:09 AM
XSV
XSV's Avatar
You must have miss this thread: https://www.clublexus.com/forums/is-...-required.html
Please do us all a favor and stop posting.
Old 05-28-12, 05:51 AM
slimjimtel
slimjimtel's Avatar
Thanks for that link, it really cleared everything up!
It's my opinion and I still don't like it. To each his own.
Quick Reply: Plastidip Troubles
