2006 IS350 feel floaty at high speed
Old 05-30-12, 01:15 PM
kinglexus99
kinglexus99's Avatar
I think you guys are missing the fact that he said he went from an 08 to an 06. That in itself regardless of tires, alignment, etc is going to be the main reason the steering feels so different. So OP before you go and spend all kinds of money on tires and alignment do some research on how lexus "recalibrated" the steering so you're not spending money to end up w/ the same results.
Old 05-30-12, 04:44 PM
anthrax144
anthrax144's Avatar
Except I have an '06 and I don't have the problem he described, actually, quite the opposite. IMO, it doesn't have anything to do with the steering ECU changes. Most likely, it's the tires or possibly the shocks starting to fail.
Old 05-30-12, 04:48 PM
knbnguyen
knbnguyen's Avatar
i redo the tired pressure and it seem a bit better now... possibly the shocks need replacement too since i know it is a 6 years old car
Old 05-30-12, 07:39 PM
FNFZ4
FNFZ4's Avatar
have the shocks checked and alignment. if it vibrates slightly have the balance checked
Old 05-30-12, 08:11 PM
phillimt
phillimt's Avatar
Originally Posted by Rikg35
What size shoe you wear.
hahaha... this was great...
Old 05-30-12, 09:30 PM
iNfectious
iNfectious's Avatar
Coming from a 97 Accord and 370Z, my '06 IS350 feels floaty too. I should say the steering wheel feel is light. I read that they improved the steering feel in later models though.
https://www.clublexus.com/forums/7241372-post5.html
Don't know if steering damper will help. Doubt it.
Old 05-30-12, 09:43 PM
Sango
Sango's Avatar
It's the steering ECU. Unless you chance the ECU, it will feel different.
Old 05-31-12, 04:52 PM
anthrax144
anthrax144's Avatar
"Floaty" and "light steering wheel feel" are two totally different things. Floaty was my '66 VW Bug at 65mph. I had to look out the windows to make sure wings hadn't sprouted. The light steering feel is because of the electronic steering and, yes, the steering damper definitely helps with this. It basically just adds weight to the steering feel.
Old 05-31-12, 04:57 PM
kinglexus99
Drive an '08 then drive your '06 and you will notice a difference.
V8drummer
Suspension and Brakes
01-28-17 10:44 PM
P128sniper
07-17-16 05:55 AM
someboy
09-07-14 04:58 PM
allst4r
12-07-09 07:05 PM
350ripper
09-11-07 08:41 PM
Quick Reply: 2006 IS350 feel floaty at high speed
