Water or condensation inside my passenger headlight
Yes, just take you bumper off and remove your headlight, remove all bulbs and moisture shields and let it dry on the sun. Bob's was actually filled with water so check that also
Thanks
Considering that there may be a leak in the seal or hole or something, wouldn't doing this be a temporary fix until the next time it rained or moisture was in the air? I'd think taking the headlight off and opening and resealing with caulk would do the trick. But i guess from your experience it must of been perhaps a headlight bulb cover or something letting the moisture in and thus after doing this method of drying it did the trick?
Thanks
Thanks
I just bought a used 06' is 350 and I have the same issue on the same side. Lexus said they wont cover it and that it'd cost about 1g to pop it off to inspect. I'm not covered under the original warranty
