Is350 fuel injector cleaner
Old 05-28-12, 07:43 PM
Shervin350
Shervin350's Avatar
Default Is350 fuel injector cleaner
hey guys any of you using a fuel injector cleaner on ur isx50, if yes whats your take on it and what brand are you using
Old 05-28-12, 08:14 PM
udithadj
udithadj's Avatar
I use 5-6 oz of lucas upper cylinder lubricant with almost every fill up. Advance autoparts have them for about $33/gallon and can their online coupons
Old 05-28-12, 08:19 PM
Shervin350
Shervin350's Avatar
notice any difference in the car
Old 05-28-12, 08:45 PM
edgeucated
edgeucated's Avatar
I use techron fuel cleaner right before every oil changes. I dont feel any difference, but it gives me peace of mind
Old 05-28-12, 10:19 PM
KillaIS250
KillaIS250's Avatar
If your using a good 91 gas, using most fuel injector cleaners will have minimal benefits.
Old 05-28-12, 11:39 PM
Toxicxk23
Toxicxk23's Avatar
Shell V-Power
Old 05-29-12, 11:54 AM
stasis3131
stasis3131's Avatar
Good gas has additives in it. Shelll v power or techron does the trick. I don't use their gas in every tank but about every 4th or 5th tank
Old 05-29-12, 12:22 PM
Kurtz
Kurtz's Avatar
FWIW all gas does.
http://www.epa.gov/otaq/regs/fuels/a...e/fact7gda.htm
Originally Posted by EPA
EPA requires the use of additives to control the formation of engine and fuel supply system deposits in all U.S. gasoline
I've yet to see any independent scientific evidence or testing showing any functional or long-term difference between any brand of gasoline in the US, despite the marketing dollars the "top tier" folks spend.
Old 05-29-12, 12:35 PM
faisal11ir
faisal11ir's Avatar
prefer opening them and cleaning them and changing the seals, did it at 120k and noticed huge difference.
Old 05-29-12, 12:37 PM
Soap
Soap's Avatar
I typically just make sure to use Chevron and every so often I fill up at Shell. I used to use cleaners, but nowadays I don't feel I need to as long as I don't fill up just anywhere.
Old 05-29-12, 01:42 PM
jbjones85
jbjones85's Avatar
I run a can of sea foam through the gas tank after each oil change.
Old 05-29-12, 01:46 PM
Gville350
Gville350's Avatar
Just take your $5 for your bottle of fuel additive and send it to my Paypal...same results! Except, I get richer. LOL!
Old 05-29-12, 01:51 PM
stasis3131
stasis3131's Avatar
^^^^ lol funny
Old 05-29-12, 02:41 PM
udithadj
udithadj's Avatar
I really don't know since I used it from the beginning . My wife's rav4 v6 sport seems to be running fine with 95k miles
Old 05-29-12, 04:51 PM
anthrax144
anthrax144's Avatar
After?? Shouldn't you do this right before you change the oil? But as was mentioned, it's not really necessary on the 350 anyhow as it doesn't suffer from the carbon buildup like the 250 does.
Quick Reply: Is350 fuel injector cleaner
