Rear Turn Signal LED Fix Decoder
Old 05-29-12, 08:40 PM
mjh09e
mjh09e's Avatar
Anyone have these? I feel like these would be the best bet.
Old 05-29-12, 09:29 PM
Sango
Sango's Avatar
You may not like them because there is no side firing as I mentioned earlier that the one I have has 12 SMD's all around in addition.
Old 05-29-12, 09:36 PM
mjh09e
mjh09e's Avatar
There are 4 side firing leds in the above picture...they are just large high powered ones.
Old 05-29-12, 09:49 PM
Sango
Sango's Avatar
Oh, yeah the rectangular. Could be possible. You may may want to find out what the lumen specs are as well. I know JLC's CREE LED is got very high lumens.
Old 05-29-12, 09:52 PM
mjh09e
mjh09e's Avatar
I think they are rated at 420...is that good?
Old 05-29-12, 10:03 PM
Sango
Sango's Avatar
A Sylvania Silverstar filament has about 465 lumens so it could be reasonable.
Side firing or the CREE itself? Seems reasonable. Keep in mind, since it's LED, the best way to test it is in the housing itself because the LED is directional. When its rated at 420, it's not the same as filiment which would be 360 degrees. As for my CREE, the JLC one has slightly more than 1.5 times the lumens output as the the one you are mentioning.
Old 05-29-12, 10:08 PM
mjh09e
mjh09e's Avatar
Interesting....still waiting to hear back from the guy on the RX forum about these. He sounds like he has all the info and is as in to bulbs as we are.
Old 05-29-12, 10:18 PM
Sango
Sango's Avatar
Oh from the RX forum. Yes I remember reading that, but they person never mentioned what the specs where and I believe there was a video too.
It does look like one from superlumination/autolumination which are China made. They have one which they say is about 500 lumens (not sure if if that is the main CREE itself, or total), and their rectangular SMDs for side firing is 100 lumens each. On the side note, some people say the the superluminaton has ok, some say quality issues.
http://autolumination.com/7443_7440.htm
Old 06-03-12, 08:27 PM
mjh09e
mjh09e's Avatar
So I installed the decoder and the leds blink much slower than the rapid blink, but still faster then normal. I am actually a little disappointed and have messaged the seller to see why this is. Still waiting for a response, but it looks like this "plug & play" option is not the best.
I will keep everyone updated as I learn more.
Old 06-03-12, 08:30 PM
Silver10
Silver10's Avatar
Post a vid of whats going on
Old 06-03-12, 08:44 PM
mjh09e
mjh09e's Avatar
^I would, but I don't have a camera other than my iPhone and have no idea how to post it to the forum. PM me and I could possibly text you one.
Old 06-03-12, 09:18 PM
Sango
Sango's Avatar
Create the video, put it on youtube and post the link here. It would be simlar to how I did my CREE LED.
Old 06-03-12, 09:25 PM
mjh09e
mjh09e's Avatar
I can describe verbally what it is doing. The decoder fixes the problem for about two seconds and then it starts blinking more rapidly, until it is basically hyper-flashing. If you have an iPhone I can text you the video.
Old 06-03-12, 10:55 PM
Sango
Sango's Avatar
I have Android.
Sounds like the decoder isn't realiable. Probably the LED turn signal relay would be better off.
I am still waiting for test and perform the resistor method on a stock resister once I get the two CREE's finally put it up in the front.
Old 06-04-12, 08:36 PM
2genIS
2genIS's Avatar
hey guys,
I replace 4 LED front signal... I bought a relay from V-LED... it work but your unlock/ lock light will not come on... V-LEd send a replacement but unfortunately it doesn't work again... I'm in the process of getting a resistor.. I think the resistor probably work a lot better then this decoder...
Quick Reply: Rear Turn Signal LED Fix Decoder
