Rear Turn Signal LED Fix Decoder
#47
It's in the diagram.
Near the top center (895A1).
It's behind somewhere around the cluster area. The only way to get to it is to remove the kick panel where the pedals are. Once that and the connectors removed, you need to sit in there head in, and use your hands and reach up. The flasher itself is held in via 85999H in the diagram, held by two tabs. Once that off, then you can take off the connector attached to the flasher itself.
kenaston99
07-13-18 07:56 PM
Lexusrhyno
ES - 6th Gen (2013-2018)
39
06-26-16 02:09 AM
