Rear Turn Signal LED Fix Decoder
Old 05-29-12, 12:31 AM
mjh09e
mjh09e's Avatar
Default Rear Turn Signal LED Fix Decoder
I have been wanting to change my rear turn signals to LEDs for months now and didn't want to (cut/tap) the factory wiring harness. I was searching eBay and finally found a plug and play solution.
Here is a link to the decoder: http://www.ebay.com/itm/7440-992-T20...#ht_3169wt_960
Has anyone used these before?
I am very excited for them to arrive later this week and will post results after the install.
Attached Thumbnails Rear Turn Signal LED Fix Decoder-7440-error-free-wire-01.jpg   Rear Turn Signal LED Fix Decoder-7440-error-free-wire-02.jpg   Rear Turn Signal LED Fix Decoder-7440-error-free-wire-03.jpg
Old 05-29-12, 01:12 AM
KillaIS250
KillaIS250's Avatar
Nice, let us know how it goes! Will be interesting to see how it works
Old 05-29-12, 04:42 AM
Hondadna4
Hondadna4's Avatar
I also want to see how this turns out. If everything works accordingly I think alot of people on this forum will has upgraded rear turn signals
Old 05-29-12, 06:56 AM
Kumar350
Kumar350's Avatar
^^^me toooo been waiting for one like this
Old 05-29-12, 08:21 AM
Sango
Sango's Avatar
I've seen them before but was not too keen on getting those, trying to figure out where to hide them and mount them.
I just got a LED turn singal relay and fire it up.
Old 05-29-12, 08:49 AM
mjh09e
mjh09e's Avatar
I figured I'd just double side tape them to a piece of metal behind the trunk liner....shouldn't be too hard.
Old 05-29-12, 08:59 AM
Sango
Sango's Avatar
Would there be a possible problem if you also do front LED? As in you need 4 or just the two would be able to do it?
Old 05-29-12, 09:11 AM
mjh09e
mjh09e's Avatar
If you already have resistors in the rear....just two for the front should do it. Willing to be the first to try the front turn signals?
Old 05-29-12, 09:22 AM
Sango
Sango's Avatar
I'm going to have front LED turn CREE's in mine soon. I already have them in the rear. They are super bright!!
I think people keep their distance, because it's white and bright? ha ha!
Old 05-29-12, 09:25 AM
mjh09e
mjh09e's Avatar
What kind of CREE bulbs? Mind sharing a pic or link to the ones you have?
Old 05-29-12, 09:27 AM
Sango
Sango's Avatar
https://www.clublexus.com/forums/is-...al-lights.html
Here you go. I have JLC's cree. The video clip I have is taken during the day to give an idea how well they do against the sun light to show their true potential. No dark video since that isn't accurate but in the dark, it is very bright!
Old 05-29-12, 09:40 AM
Samieee
Samieee's Avatar
Isn't a relay enough?
Old 05-29-12, 09:48 AM
mjh09e
mjh09e's Avatar
Thank you...those look awesome. I just looked on v-leds.com since they are having a 15% off Memorial Day sale until the 31st and found these in red: http://www.v-leds.com/RED-7440-11W-H...95540-1-2.html
Looks like a similar kind of concept....might try these.
Old 05-29-12, 10:36 AM
mjh09e
mjh09e's Avatar
A relay is probably enough, but this is for those that either want a plug and play solution or do not want to tap or cut any of the factory harnesses.
Old 05-29-12, 11:45 AM
Sango
Sango's Avatar
You can get the ones from JLC. They also have 12 of the 5050 SMDs going all around to fill the housing. The VLED ones don't look like they surround the housing so it's mainly going to give a projection look without filling in the housing.
The LEDs are from Japan. I got mine from a CL vendor for discount.
Quick Reply: Rear Turn Signal LED Fix Decoder
