Weird smell from AC vents..?
Old 05-30-12, 03:15 PM
kingster
kingster's Avatar
Originally Posted by Herofmine
I have same problem, when i turn on heat it gets worst can breath inside the car, i have new cabin filter, can't figure out the problem
I could swear reading some time ago about this same issue and some member/s turn on the heather for a couple of minutes to dry out the moist before turning on the A/C. I guees that does not work.
Old 05-30-12, 03:28 PM
kingster
kingster's Avatar
There is nothing worst than having your owsome date in your luxury leather interior but not knowing what to tell her because it smells as if you had a public urinal in your car as well.
Now I understand some girls not wanting a second date.
Old 05-30-12, 05:19 PM
boss22
boss22's Avatar
is that smell is that bad in your car??? that sucks bro...
Old 05-30-12, 05:21 PM
Silver10
Silver10's Avatar
http://www.lysol.com/cleaning-produc...ir-fabric-mist Walmart has this and some dollar stores too $5-6
Old 05-30-12, 06:19 PM
KINETICS
KINETICS's Avatar
freon recharge? or there's something that got caught in the vents?
Old 05-30-12, 07:34 PM
FNFZ4
FNFZ4's Avatar
it could be the cabin filter.
Old 05-30-12, 07:52 PM
boss22
boss22's Avatar
what do you think about this one here:
http://www.ebay.com/itm/160604132141...84.m1438.l2649
Is this going to be a better brand than ex. Fram?
Old 05-30-12, 08:18 PM
LDNN
LDNN's Avatar
Originally Posted by Silver10
I just use Lysol fresh breeze in the outside air vent by windshield with the A/C on fresh air on high and spray then turn heat on and that nasty smell went bye bye. You could also use febreeze but Lysol kills 99.9% bacteria
Awesome info, thank you!
Old 05-30-12, 08:34 PM
boss22
boss22's Avatar
I've ordered already.
I going to replce the cab filter, refill the AC and also I going to try the Lysol or other AC kit in the vents. We will see...
Old 05-31-12, 09:30 AM
soysauce12
soysauce12's Avatar
Default Share the results
Let me know how that goes... I want to fix my smell issue also...
Old 06-03-12, 05:04 PM
greg0723
greg0723's Avatar
Originally Posted by slimjimtel
There is also this...Toyota AC Refresher kit.
http://lexus.sewellparts.com/accesso...1999/4481.html
im sorry but dont waste you money on this. i bought it and took it to lexus because i didnt know how to use it. the drain line they have to stick the tube in to to foam out the smell is under the transmission they told me. not sure how true it is but i didnt get it done. my boy gs350 has the same smell and he lives an hour away from me. maybe this is this lexus generation issue?
Old 06-03-12, 07:26 PM
jgbackes
jgbackes's Avatar
Interesting How-to
http://www.ehow.com/how_5087804_clea...ng-system.html
This is the spay I have used in other cars when I lived in the mid-west.
http://www.drugstore.com/earthworm-n...ment/qxp343553
jeff
Old 06-04-12, 04:42 PM
boss22
boss22's Avatar
Originally Posted by jgbackes
Interesting How-to
jeff
this may work.
I bought a special spray at Advance Auto Parts and I going to use it in my car soon.
Label says that you have to turn the AC on then fan to the max set and set your car on fresh air intake then you go outside and spray half bottle into the fresh air intake, then let it run a couple of minutes and turn fan off let the AC run and spray a little into the each vent.
Hope that going to work if not I gonna buy another one and go through process all over even a couple of times to get rid of that crap.
also i bought a carbon cabin filter on ebay, we''ll see.
Old 06-04-12, 04:50 PM
nosurprise
nosurprise's Avatar
I was doing the AC off trick that seems to work, but got tired of keep turning it on and off. What I noticed is that every time I turned the AC off, the air recirculation is also changed to fresh air. I've been exprimenting just don't do air recirculation for the past few days and it seems to get rid of the smell. This might also explain why I started to get this smell in the summer as my car automatically switch to recirculation more often ....
I was talking to my brother about this weird smell, and he said that he also has a little bit of it in his BMW, though not nearly as bad.
Old 06-04-12, 06:28 PM
Tvanallen
Tvanallen's Avatar
Default A/C smells like nasty cheese
If your car is still under warranty...good news, there is a fix. If not, you may not want to read this cause it will probably be very expensive.
I bought a 2008 IS 250 with 25,000 miles on it and this smell started the first summer. We took it in and they did an Ozone machine treatment, didn't work. Then they did the foam treatment, worked for a week. Took it back and they took the whole dash out and replaced the condensing unit and said that they had improved the design of the system since my car was made as it retained moisture in whatever material is surrounding the system. They also said that leaving the A/C in recirculating adds to the moisture build up and that if I could remember to switch it to outside air before turning the car off..ya right.
I have no more smell after the change out.
Quick Reply: Weird smell from AC vents..?
