Weird smell from AC vents..?
Old 07-22-13, 06:08 PM
  #61
showtymers
showtymers's Avatar
do you guys ever vacuum your carpets often ? .. i really think this is where the problem is coming from.. if you are constantly on recirculate all the air its grabbing is from the foot area vacuum it and see if goes away .. or do you all have sweaty stinky feet ? =P be honest
Old 07-22-13, 08:18 PM
  #62
drewster12
drewster12's Avatar
So I have had the nasty odor on my cars repeatedly. It's the evaporator core. My solution, and it has to be reapplied, is to use one of the following:
http://www.autogeek.net/1z-einszett-...freshener.html
http://www.autogeek.net/1z-klima-cle...sy-to-use.html
Essentially the first one is a foam that cleans out the core. The second one is a fogger that does the same, but not as effective. I like both, but the second one is so easy to use.
Some other things you can do to ensure the odor is eliminated is by turning off the AC 5 minutes to your destination. If the core is dry, mold and fungus cannot grow. You could also turn up the heat, set the circulation to fresh, and let this run with your windows open for 15 minutes. This particular method fries the mold.
Old 07-22-13, 09:33 PM
  #63
dong888
dong888's Avatar
Dealer vacuum my carpet when I change oil there.
A very good way to remove odor is to buy charcoal. Google it and u will fine charcoal sold to remove odor. I was cheap so I bought the one put inside the shoes overnight. Jus leave them in the car and my car is odorless. Best part is charcoal is reusable. Just put them under the sun for a few hours and it will work ver well again.
aachowhan
10-13-19 07:53 AM
Pittsy
10-10-18 05:44 PM
20LS01
09-27-16 04:47 PM
lexuspower
05-25-11 06:38 AM
gs3_4me
08-20-03 04:30 AM
Quick Reply: Weird smell from AC vents..?
