Damaged Undercarriage how much to repair?
Hello all,
it was a bad day for my Lexus IS (2008) today. As i was on the on ramp for the highway in my city of san antonio i ran over a 4X4 2 foot long block with my lexus. It is a one lane on ramp and elevated and narrow at that. I couldn't dodge it, especially since there was traffic behind me. Only option was to run over it straight on so i didn't crash by it hitting my wheels. Sounded horrible but my front end aesthetically looks fine. Driving is normal. Only damage was the under carriage reenforced plastic that goes under the engine.
Any one know or have any opinions on how to fix this. Thanks!
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
I agree. I had my plastic engine plate fall off my G35 on a road trip, drove 200 miles with it scrapping on the ground with only a couple bolts holding it to the car. Mechanic said its only purpose was prevent things from getting sucked up into the engine compartment and causing damage to the moving parts. He replaced the bolts for $10 and sent me on my way.
you will be fine with it as is, without it, or replacing it. the plastic under tray has multiple purposes.
it keeps road debris out of the engine bay (imagine a newspaper getting lodged next to your exhaust manifold & causing a fire.) it is also used for under car aerodynamics and more importantly engine cooling. the plastic tray has strategic vents/holes in it to allow the high pressure hot air to escape from the engine bay, into the low pressure zone that is under the car. without it, air would be entering from your grill as well as from under the car, causing a turbulent mess
The undertray does more than just stop water or debis from entering the engine bay. It effects downforce. Toyota put those there to create a flat floor that smoothes the airflow. Since the air under the car is smoother, thanks to the undertray, the air going around the top of car has to travel faster, pushing the car down.
You can run the car without the undertrays, but you might loose 1% ( my guess) aerodynamic efficiency and some high speed grip
EDIT: Thanks to Clubfoot for correcting my mistake. Smooth air flow under the care increases flow, creating a area of low pressure, and increases downflorce. .
The undertray does more than just stop water or debis from entering the engine bay. It effects downforce. Toyota put those there to create a flat floor that smoothes the airflow. Since the air under the car is smoother, thanks to the undertray, the air going around the top of car has to travel faster, pushing the car down. The car acts like a upside-down airplane wing, if you can imagine it.
You can run the car without the undertrays, but you might loose 1% ( my guess) aerodynamic efficiency and some high speed grip.
Like many said it is to keep debris away from the components. One of my friends rented a car for a road trip that did not have anything protecting that area and while we were in the middle of nowhere, well we ran over something that cut the radiator tube. We were unaware of this until the car overheated from lack of any coolant and would not restart even after the engine cooled down.
