Engine Oil for IS350
Old 06-07-12, 02:41 PM
neomedic
neomedic's Avatar
Default Engine Oil for IS350
Just wanted to know what oils you guys run for an IS350??
Who is the resident expert on oil and frequents BobIsTheOilGuy forum???
I guess Mobil 1 5W30 is fine if changing every 5K - 8K. But wanted know if something might be better without the extra cost. If it was like $15-20 more per oil change, I might consider it.
Thanks.
Old 06-07-12, 02:42 PM
bob4256
bob4256's Avatar
I guess Mobil 1 5W30 is fine if changing every 5K. But wanted know if something might be better without the extra cost. If it was like $15-20 more per oil change, I might consider it.
Thanks.
I just started using Royal Purple and have noticed that my car runs smoother.
Old 06-07-12, 05:02 PM
whitebeast
whitebeast's Avatar
Mobil 1 + lucas pure synthetic is what i use
Old 06-07-12, 05:49 PM
KINETICS
KINETICS's Avatar
regarding this oil...I've read that the new models now run 0w-20 rather than the traditional 5W-30. I guess they do it for better MPG. What do you guys think of running 0W-30? on an 08 IS250?
Old 06-07-12, 05:50 PM
bob4256
bob4256's Avatar
I think the new ones use 5W-20
Old 06-07-12, 07:47 PM
Slammer1
Slammer1's Avatar
My '06 IS350 originally came with 5-30, but there was soon a TSB instructing the dealers to switch to 5-20 in this car. I have owned the car for almost two years, and have run Mobil 1 5-20 Synthetic since I've had it. I use Purolator filters, btw. But you can usually score the factory Toyota filters pretty cheap from Sewell. I am curious about the Royal Purple, as I have heard a lot about it. It is only about a dollar a quart more than the Mobil 1 if you buy it by the quart, but I get the 5 quart jug of Mobil 1 from Walmart for about $26, which is by far cheaper than anyone else....
Old 06-07-12, 07:54 PM
heyarms
heyarms's Avatar
Sure ya do...
Old 06-07-12, 08:11 PM
bob4256
bob4256's Avatar
Originally Posted by heyarms
Sure ya do...
Keep in mind I just switched from conventional oil to synthetic. I know people say they dont think RP is better but I have no problem spending a few extra bucks for oil. Only the best for my baby
Old 06-07-12, 08:45 PM
baputsti
baputsti's Avatar
Can't go wrong with German Castrol 0W-30. A lot of FI guys run this oil.
Old 06-07-12, 10:06 PM
SRakaSSS
SRakaSSS's Avatar
Yes. My 2011 uses 0W-20 and I'm assuming 2011+ use it as well.
Old 06-07-12, 10:10 PM
Soap
Soap's Avatar
I use Mobil 1 synthetic 5W-30 and a WIX filter every 10,000 miles
Old 06-07-12, 10:23 PM
neomedic
neomedic's Avatar
Anyone have a link / copy of the TSB that says to switch to 5-20 for this car? Is this switch even for older 2007 IS350???
What's better for protection? 20 or 30?? I don't care about gas mileage. It's not going to make that much of difference for me. Rather save the engine and keep the car till 150K+ than more ware and tear for a gas savings.
thanks.
Old 06-07-12, 10:25 PM
allst4r
allst4r's Avatar
07 is350 using 0w20 for 5 years now. no issues. in so cali
KillaIS250
KillaIS250's Avatar
thanks.
It was 2006 only. 07-10 still run 5W30
No reason to run a WIX filter, OEM filters are cheap and what the car was designed with
Old 06-07-12, 10:32 PM
phillimt
phillimt's Avatar
i've always used oem filters, and 5w30 mobil 1. I consider mobil 1 to be really good products, and I've noticed the difference switching from castrol blends that the dealer used to throw in my car. mobil 1 is high quality stuff, i'd recommend spending the extra few $$ on this, and I personally think that's good enough. these forums are full of people who live and swear by mobil 1, so i'd recommend using that personally.
I use it in my 1997 honda accord these days even, with 150,xxx miles. it's just awesome stuff.
09 250.
Quick Reply: Engine Oil for IS350
