Lowering with 20's F Sport Springs
Is anybody running 20's with F Sport Springs? Is so, how is that going? What tire size are you running? I'm thinking about lowering it but first I need some feed back. Thank you!
I used to be on 20s with F-sport springs, its not really even a full inch. And with 20s youll still be a little higher than stock. If you dont want to spend the money on coils, I suggest the Tein S.Tech springs, theyre a little lower and cheaper than F-Sports. And theyre still good with stock shocks.
245-30&255-30 i would get bigger tire to the back next time i change the tire, guys to get the most drop out of springs is when you or the installer install the upper top mount, there are rubber gasket sit on top of the coil before put the upper pillow mount back make you align that rubber piece where it meet the coil before because that spot was press down due to the old spring was set, it would give you another half an inch lower. I know you guys might not believe me, but i proved after installed for my friend is350 and mine, mine is sit lower than his and we both have the same f-sport suspension and same tire size too
JM Lexus installed them. I had pretty much the same wheel gap, but body to floor was too high for me. Then I got the tein s.techs. Now its finally on megan coils
I know coilover will give you more low, it also eat the tires quick too, and how long those coilover would last? I had Tein type flex for my previous is300 and i hate to change the tires for every 8 k, to me f-sport perfect dd and coil for shown unless u have money to spend on the tires
With 20's, I don't want to go too low but at least a little lower, fill in the gaps a little more you know? So i was thinking Sport springs? Other than F Sport springs, any recommendations? I want something in that nature.
