Installed my new ballast today in the passenger headlight. Turned it on only to see the light flicker on then off for a split second. I have checked the bulb, the fuse in the engine bay, and now I'm at a loss.....any ideas on what else it could be?
I see that you checked the bulb, I would suggest to swap it with the bulb from the other side or with a new spare bulb to really eliminate the possibility of the bulb.
Arrggg, I was hoping they weren't together to get this solved.....Maybe its a fuse or maybe the new ballast is defective...dunno, I guess I'll be paying the dealer a visit!
I am having the same problem with my passenger side low beam not working even after exchanging bulb to the other side. I found this solution and am wondering if it'd be the same for IS's. It's saying their integrate relays and the entire fuse panel has to be replaced. https://www.clublexus.com/forums/ls-...l#post11504865
