Best method to repair cracked paint from fender rolling?
Old 06-11-12 | 02:27 PM
Sffd103's Avatar
Sffd103
Fire Slayer
repaint pint the entire fender/pane. That's the RIGH way!
Old 06-11-12 | 02:41 PM
heyarms's Avatar
heyarms
For those who assumed otherwise/wasnt clear to begin with, it was done by a reputable shop in Houston who was informed of the prior work on the body panel. A heat gun was used but they assume the paint was layered on thicker and thats what likely caused the paint to crack. Rolling fenders is not fail proof. *see google *
Sadly, this is the truth. Just bought that LMS Kit though!! haha
Originally Posted by ibidu1
You need to understand why it cracked. You said there was prior damage to that panel. Most likely theres a thin layer of bondo, bondo is not as flexible as paint, that is why it cracked.
You should have used a cutoff wheel or dremel and cut the inner lip off and rolled just the tip. We live and learn!
I have pictures from the repair work and it didnt look like bondo was used, and the portion that was most deformed was at the highest point of the fender, not where it cracked. It was just a light tire rub from a jeep that caught the fender in a parking lot so it was just reworked and painted as far as pictures can tell and from what i know. Your truth comes in the suggestion of cutting the outter portion and rolling the upper most area. Live and learn, for sure.
Thanks for those who helped and didnt venture off-topic.
Old 06-11-12 | 02:53 PM
Sffd103's Avatar
Sffd103
Fire Slayer
I'm gonna venture off now, you bought the LMS? Nice! I remember you asking about an S/C kit. Good luck!
Old 06-11-12 | 04:01 PM
heyarms's Avatar
heyarms
Yessir, I picked it up after a ton of questions to him, ATI Procharger and my shop. Expect it installed mid next week at the latest.
Old 06-11-12 | 08:34 PM
600rr05's Avatar
600rr05
vote for # 2 since it makes sense since you said they didn't do a good job..
pandatroop
02-03-17 09:48 PM
ThreeFive0
12-10-12 01:24 PM
shsd
05-04-12 03:54 PM
menty
SC- 1st Gen (1992-2000)
02-19-08 05:30 PM
chrispy
05-13-06 11:51 AM
