Navigation problem
So EVERY time I get in my car and my Nav screen turns on. It clicks a point and does not get off it til I push a button. So every time I have to push a button to get it to follow me. It's more an annoyance thing than a defect. But does anyone know what might have happened to do this. This is a new issue. I don't believe I have changed or clicked anything inside.
No i will turn the car on and it will beep and select a point on the map that I didn't click. Like say if you touch the map it tells you can find route guidance to that point. It does that automatically. And it does it every time.
you sure you don't have the "i agree" feature in the ml+ enabled?
sounds like it's enabled and every time you start the car, the unit tries to "press" the i agree button for you, thus shifting the map to a bit lower right hand corner. disabling that and you should be ok
greg s
11-21-14 01:22 PM
