Swap out to HID Fogs w/o removing Bumper?
I have 3 screws left underneath because I keep losing them. I have had no problems. To go in through the wheel well you have to take your wheels off or turn them back and forth. There is also the problem or bending your fender liner and scratching your bumper cover the sides. You will have a garbage looking install because the fender liners are a pain.
TAKE YOUR BUMPER OFF. Like it's been said, it's not hard, and you will be able to do a much cleaner install that will have fewer problems later. The first time I did mine, I went through the fender. I ended up having to pull the bumper off later to fix the garbage install and do it properly anyways. save yourself the trouble.
Former Sponsor
Do it right once so you don't have to keep re-doing it down the road.
