/Camber Install\
Alright guys, I have a few question that'd would be awesome if they were answered. At the moment, I'm installing both SPC front ball joints & Megan rear camber arms on my 350. But this is where I'm at an impass. My car has been out of comission for about two weeks now as I've been busy installing everything from a new hood, to PPE headers, to fog lights and blah blah blah in my garage. The last thing I need to take care of is installing the ball joints and camber arms.
Any idea how to install the SPC ball joints?
I've obviously taken of the wheel, and then removed the cotter key and nut, and broke the ball joint from the knuckle. But what's next? Removed the wire and the small dust boot, and partially took care of the snap ring. From there do I push the ball joint up and out? I got a ball joint press from my local Autozone but have no clue how to work it. Any and all help would be appreciated.
Megan Rear Camber Arm
Has someone done a DIY for this? Some threads have a couple pictures, but no real detail about HOW to install them, or even how to remove the stock ones. At that, how do you even adjust the Megan arms? I need more camber at the front and back for more slammage![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Sorry for the novel of questions, but I'm looking forward to getting this done![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Any help would be greatly appreciated, and if anyone finds a thread with anymore info, by all means direct me to it, thanks.
Ok, that's good news. So you said there are only two nuts or bolts holding in the stock arms? Are they hard to get to at all? I haven't seen my suspension geometry in a while so I don't remember where every single arm is.
Thanks MyIS350G,appreciate it. Any more info on this stuff guys? For the SPC ball joint install, do I need to take out the UCA to get the OEM ball joint out and be able to put the adjustabe ones in?
One other thing when I did mine SPC did not over an ISX50 specific part so I had to grind the lip of the UCA so the slide mechanism of the ball joint could be adjusted.
^SPC did mention in my instructions if you are going to be inducing postive camber that to be able to max it out you will need to grind a lip on the arm. I have yet to do it, but I'd assume it's not much material to remove.
And a tip...use some blue Locktite on the top threaded portion of the ball joint in order to keep that top nut locked down tight.
GL!
GL!
GSracerRY
Suspension
07-28-14 06:51 AM
Sportskid1
Suspension and Brakes
35
12-13-13 10:59 PM
aQuarius26
03-22-13 07:54 AM
