Is350 advan rs
help please, looken at Advan Rs set. i have an 06 is350 currently stock (not lowered)
want to buy these
Wheel Size: 18 x 9,18x10
Wheel finish: Matte Black
Bolt Pattern: 5 x 114.3
Wheel Offset: +25 18x10.0 +25mm offset, 5x114.3 (Matte Black )
BFGoodrich G Force KDW tires staggered fitment
Front-245/40 ZR18 93Y
Rear-275/40 ZR18 99Y
will i need spacers. or will they be to wide.
do i need to mod anything if i dont lower it right away?
would it look funny?
any suggestions and help is greatly appreciated.
want to buy these
It will not look right without dropping it, it would sorta of look like a mexiflush. I also think you'd rub in some situations with those tires.
Those tires are way too wide. 225/40 and 255/40 Is the max tire you can run if that's what you're into. With those and a mild drop, you will need to roll your front and rear fenders.
the set comes with those, i figured i would have to sell the tires if i want them. a mild drop would be how much lower? wife would sometimes drive it so i wouldnt be able to slam it : ( is 225. 255/ 40s the best sizing?
those rim specs otherwise work?
want to buy these
want to buy these
![](http://i8.photobucket.com/albums/a31/CrimsonIncarnate/dcc34680-1.jpg)
I am running Advan's RS 19x9 +22 19x10 +25. You will not need spacers. They will poke a slight bit. You will definitely need fender work for wheels that aggressive. My tires are 215/35 and 235/35. I am fairly lowered though, at about 24.75" from ground to fender. I suggest lowering your car first, getting the proper fender work done, then getting the wheels. You will love the look.
where does one go to get fender work done? and what should i expect to pay?
thanks and yes. i love the way your ride looks!
With wheels that aggressive, it's also the rim itself coming in contact with the fender. I'm stretching tires, and I needed fender work anyways. If you're planning on running fatter tires (which it looks like you are), I would do fender work. Of course, this is all dependent on how low your car is. Better safe than sorry. You don't want those expensive Advans bumping up against your fenders.
