Guys who have used Dr. Colorchip
So I used it today and I don't know if I'm expecting too much but I'm not satisfied.
I followed the steps on how to do them and it was so hard to wipe off the paint with the sealer it came with. I let the paint dry for 30 minutes and it was so hard to wipe off the excess paint. I had to rub it off and The finish still had chips but instead of the chips being white, the chips were dark blue which is my cars paint. What could I have done wrong?
Did I use too much paint in order for me to have trouble wiping the excess paint off? It says don't rub hard but I had to cause it was hard to remove the excess paint.
I've used it and was pleased with the results. If it's a deep scratch or ding...you'll need to do that spot several times because it fills in the gouge with paint and you basically try and blend it out with your finger. Yes the longer you let it sit the harder it will be to remove the excess paint. Although it was tough at first...I kept at it...the excess turned a faint white...like a dried smudge and eventually wiped clean. My car is Smokey Granite.
