Have I blown a shock?
Old 06-26-12, 07:05 AM
Vibes63
Vibes63's Avatar
Default Have I blown a shock?
I, now a days hear this thumping sound from my right rear shock maybe both rear shocks when I go over a bump. Could I have blown my shock?
Thx
V
Old 06-26-12, 12:14 PM
evogt500
evogt500's Avatar
Check to see if theres fluid coming out of the shock. Push the car down with your body weight, near the suspected blown shock. Once you let go, it shouldn't contimue to bounce up and down. If it does it COULD mean you have a blown shock. I would also check the suspension bushings for wear. It could be the bushings that are making the noise.
Old 06-26-12, 12:46 PM
MamadIS
MamadIS's Avatar
most likely yes. i've been hearing this thumping and clunking noise coming from my driver side wheel everytime going over bumps or uneven road. took the car for check up and found out that my front driver shock is leaking. i was kinda surprised cause i only have like 70k on the car and never driven aggressively. so based on what you described its most likely blown shock.
Old 06-26-12, 01:35 PM
Gville350
Gville350's Avatar
Stock shocks and stock springs?
Old 06-26-12, 02:37 PM
Vibes63
Vibes63's Avatar
Yes stock springs and shocks.
Old 06-26-12, 02:58 PM
tedward88
tedward88's Avatar
is the car extremely bouncy when you hit the brakes or run through a speed bump?
Old 06-28-12, 05:26 AM
Vibes63
Vibes63's Avatar
Not bouncy. Just makes a thud sound in the right rear over bumps.
350PsDMeuP
Suspension and Brakes
02-16-10 03:21 PM
IS350HKS
12-11-09 03:41 PM
ecstaticSC
07-29-06 01:41 AM
martialart
10-10-03 08:00 PM
alkattan
01-01-03 04:56 AM
Quick Reply: Have I blown a shock?
