Burnt out ballasts?
Old 06-29-12, 09:32 AM
Vibes63
Vibes63's Avatar
Default Burnt out ballasts?
I tried to install an led drl kit and no sucess. Now no bulbs will light on both high beam and drl. Any advice?
Old 06-29-12, 10:03 AM
Proper 350
Proper 350's Avatar
Check your fuses 1st. Not sure where that fuse is located but all fuse locations are at the feet of driver and passenger and both sides of engine bay.
Old 06-29-12, 11:06 AM
Eazy350
Eazy350's Avatar
its the fuse under the hood. had the same thing happen to me i think it was a red one closest to the windshield
Old 06-29-12, 11:38 AM
iJDMTOY
Former Sponsor
iJDMTOY's Avatar
1. Check polarity of the wires (make sure that the positive wire is connected to the positive, and negative to negative, USE A TEST LIGHT TO CHECK). Some Lexus vehicles may have to have the harness plugged upside down to work.
2. If polarity is correct, check the fuses. The DRL fuse should be in the engine bay, on the side of the fuse box.
Old 06-30-12, 07:25 AM
Vibes63
Vibes63's Avatar
I'll check it out today. I think it might be a fuse. Do I have to go to Lexus dealer to buy the fuse?
Old 06-30-12, 07:28 AM
minato
minato's Avatar
they are the regular little fuses, i got mine from a car shop for free, when i installed my hid fogs and the fusebox for the lights should be under the hood..
Old 06-30-12, 10:56 AM
Vibes63
Vibes63's Avatar
Done! Fixed. I blew out my fuse. Lights are good to go!
Old 06-30-12, 10:57 AM
Vibes63
Vibes63's Avatar
IJDM - the bulbs seems a little dull. Is that how they are normally for the 68SMD Led bulb?
Old 07-06-12, 05:51 PM
iJDMTOY
Former Sponsor
iJDMTOY's Avatar
It's a subjective definition, but we do offer brighter LED bulbs if you are unsatisfied with the output of the 68-SMD one. We have LED bulbs that have up to 120-SMD LED chips and are a bit brighter.
Personally, I run the 120-SMD Bulbs and they're great! LMK if you're interested in exchanging.
kurtismt19
ES - 5th Gen (2007-2012)
05-18-19 06:45 PM
chanho083
11-29-16 10:41 AM
ReyRey305
08-08-14 09:36 PM
redholm
RX - 1st Gen (1999-2003)
11-25-12 01:35 PM
g356gear
IS F (2008-2014)
10-10-12 04:18 PM
Quick Reply: Burnt out ballasts?
