2007-8 IS350 Sport... Lux + Mods Equivalent.. helppp
Old 07-04-12, 03:54 PM
BrooklynNY
BrooklynNY's Avatar
Default 2007-8 IS350 Sport... Lux + Mods Equivalent.. helppp
It is very difficult to find a clean 2007-8 IS350 Sport w/ Nav... I plan on adding an IS-F steering damper, F-Sport Sways... would these options + some coils (not crazy low -_-) on a Lux package 350 feel practiclly the same as the 350 Sport package with its sport suspension..
I would also plan to do a trim wrap (aluminum) + add sport pedals however those are cosmetic, mostly concerned with the ride.. perhaps a 1:1 trade with a member on here or even Sewell trim purchase (pretty costly)
does this seem practical.. or should I continue to look for a clean 2007-8 350 sport package.. white or SGM
***Mods.. I did post this in the Suspension section but it really got no attention or responses.. please pardon it in this general section now***
Old 07-04-12, 07:18 PM
Kurtz
Kurtz's Avatar
The only suspension difference between them is springs and shocks, so you could swap those over, or get coilovers with similar spring rates and be good....the sway bars and steering are identical in both packages so the mods you suggest, while good, would go beyond the stock sport package "feel"
Ideally you'd find someone willing to swap interior trim with you 1:1... do those things and only stuff left would be sport pedals (since the scuff plates are better on lux IMHO)
I'd also say get an 08 if you can, steering feel is better (regardless of package) compared to 06-07.... unless you plan to swap an 11+ F-sport steering ECU (not terribly cheap).
AndrewT122
03-13-14 04:51 PM
gFREAKy
09-13-12 09:26 AM
jtwenger
Suspension and Brakes
08-15-12 11:32 AM
BrooklynNY
07-03-12 09:01 PM
Nashtyboy
10-28-07 07:23 PM
Quick Reply: 2007-8 IS350 Sport... Lux + Mods Equivalent.. helppp
