AfterMarket Amp Install Help.
1. You have to remove the rear seats to access the factory sub. It has a harness that you can just disconnect; there is no wire cutting involved.
2. The orange wire on the end of the second connector is the correct one. It's what I used, documented in post #181 of the aforementioned DIY amp install thread.
3. Good luck!
3. Good luck!
Did you see the pic i posted in my 1st post? From what you are saying i think i have connected it to the right wire....
i have it circled in red in the pic posted in the 1st post...
and thank you
finally got that over with...
Now, to unhook the factory sub and connect the amp power wire to the battery and i'm done.!
woohoo!!!!!
***Thank You Everyone That Helped Me...
Pnuge88
01-12-11 11:44 AM
lexus37
09-12-10 08:26 PM
SC300_704
12-02-06 12:56 PM
