2006 is250 reliablility
Old 07-10-12, 09:00 AM
Silvicious
Silvicious's Avatar
hahahahahhaha. got it. well no problem there.
Old 07-10-12, 09:03 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
WOT is wide open throttle, and as for the carbon issue, going WOT will do nothing to prevent or help it.
Jeff
Old 07-10-12, 09:10 AM
zen
zen's Avatar
You can give a try to explain the rough idle on the engine and the dealership would probably replace the piston and piston ring. From what I heard, all Lexus dealers requires to have check engine light associate with the carbon build up issue for the replacement on piston and piston ring, or short block if there are any scratches on the walls.
The engine is still ok since Lexus use the same engine in the 2012+ GS250 in Asia and UK region. The same engine has about 8HP more than North American region. The emission control in North America detuned the engine which it's a lost of 8HP in the IS250.
If the engine has serious flaws or problems, Lexus wouldn't use the same engine on the newer models.
Old 07-10-12, 09:35 AM
My0gr81
My0gr81's Avatar
That is really not an indication of reliability. Lexus may just use the same engine if it is cheaper to deal with the expected warranty rate than developing a new engine at that particular time for that particular market.
Not wanting to turn this thread into a carbon build up discussion, but I think that the emission controls in NA have something to do with the carbon build up issue as recirculating exhaust gases into the combustion cycle is bound to create contamination in the combustion chambers.
I had an Infiniti G20 with the SR20 engine that was notorious with clogging out the EGR valve and tubes with gunk from recirculation gases. Every 3 months, I would have to take the tubing apart and clean everything with carburator cleaner. That car lasted from 1991 to 2008 as ours, and then our mechanic bought it for his daughter and still going.
Old 07-10-12, 01:55 PM
zen
zen's Avatar
I think perhaps it's true that the emission control in North America is the cause for carbon buildup in the IS250.
However, the engine is used on a various vehcles since almost 10yrs ago and on to the newer models. I would think the engine's reliability shouldn't be as bad as we thought. Also besides from the carbon buildup, I haven't heard/read any other issues.
Old 07-10-12, 02:03 PM
Silvicious
Silvicious's Avatar
well, i read recently about pistons being replaced and idling being "rough". i dont really know how to pick out "rough" idling. would indicators be noises and high idling???
electrope
02-19-19 07:57 AM
gkitsi
08-13-18 01:02 PM
ykul90
01-02-17 02:28 PM
LexusFan09
02-12-15 07:14 PM
nprice2
09-11-13 05:55 PM
Quick Reply: 2006 is250 reliablility
