Old 01-06-15, 05:08 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
Installing a new windshield myself
Old 07-23-16, 12:00 PM
  #61
nyis250
nyis250's Avatar
Jeff,
I went to the dealership to order my parts and they said the DAM, Window Glass Ad (Part # 56117-53020) is not required. Can you confirm what this part is used for? Will the install be good without this part?
Old 07-23-16, 02:20 PM
  #62
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
It depends how you are installing the glass. If you install it as per Lexus' instructions, it is much better to have the dam in place. If you do it the way most glass people do it, it's not going to do much (they slam the glue down on the body instead of the glass). Most customers/installers probably never use the dam, and if they do, they probably don't use it correctly.
I used it.
You can see it before applying the adhesive in this photo:
You can see it beside the adhesive in this photo:
Jeff
Old 08-16-20, 10:27 PM
  #63
Yamehoo
Yamehoo's Avatar
Hey Jeff, could you kindly send me the link where you got the Drive Joy kit. I want to tackle this job myself soon. Thanks.
Old 08-18-20, 08:57 AM
  #64
2013FSport
2013FSport's Avatar
Received 1,529 Likes on 1,272 Posts
This belongs here. Heated glass PNs...
Originally Posted by Jeff Lange
The windshield glass should be available in the USA without issue. The part numbers are as follows:
56101-53959 - Glass, Windshield (w/Deicer)
84794-33020 - Switch, Windshield Deicer (2010-2011, LH side of the steering wheel)
84794-52010 - Switch, Windshield Deicer (2012-2013, RH side of the steering wheel)
88263-21010 - Relay, Windshield Deicer (LH engine bay relay block, near firewall)
US cars will have the wiring for the relay and the glass itself, up to the dash harness. The dash harness for US-spec cars will likely have the wiring for the switch on Cold Area Spec cars, others may not, I cannot confirm either way. If not, it's a relatively simple thing to add to control the heater circuit.
Jeff
korupted
08-08-17 05:58 AM
ba2sy
RC F (2015-present)
08-05-17 10:34 PM
LexTones
CT 200h Model (2011-2017)
01-25-16 04:42 PM
bg_281
09-10-09 08:53 AM
e-man
10-01-06 10:26 AM
Quick Reply: Installing a new windshield myself
