LED DRL or Halogen?
LED DRL or Halogen?
Hi all, I currently have an 06 IS250 with blue LED DRLs that were installed by the previous owner. However, I'm not too pleased with them. They're not as bright as I would like and because it's LED theres no high beam functionality.
I'm debating about switching to brighter white LEDs or going back to halogen so I can use my high beams. I know everyone has different personal preference, but I would like to hear what your opinions are.
If for a brighter white LED, what would you recommend? If halogen, which bulbs are popular/reliable?
Thanks!
Thanks!
Do you have the factory bi-xenons that adjust with your steering? If so, I would stick with the LED DRL because if put ur high beems on they will still point upwards. If you don't, then maybe a switch back to halogens is better for you.
For brighter led... Go with the VLEDS kit in 5000K if you want it more white then blue.
If for a brighter white LEDs, what would you recommend? If halogen, which bulbs are popular/reliable?
Thanks!
Thanks!
The 68-SMD LED bulb we carry does the job quite well, but if you want something that is slightly brighter (still not bright enough to be functional as high beams, but definitely still brighter), you can go with the bulbs with more LED chips. I personally run the 120-SMD LED bulbs and they're great.
Thanks, that no workie for me. My preferred commute route is a nice little back road; lots of twists and ups/downs, but also alot of the 4-legged friends that can smash up my car.
This sucks, I really dislike that ugly yellow of the halogens but cannot lose HB's.
