Is it me or is it really hot when AC is off?
Old 07-23-12, 03:28 AM
jgbackes
jgbackes's Avatar
Originally Posted by My0gr81
This doesn't help anyone since you don't mention what harness terminal 6 and terminal 7 are from.
the simpler way is just switch to fresh air mode and increase fan speed, hear the air flow, then switch to recirc, and you will hear and feel the flow change. Recirc does just that, the hotter it is, the worst you will feel as your own body will add moisture to the air increasing the relative humidity in the cabin. Fresh air will keep the RH down, and bring in a little colder air as it moves through the ventilation system faster when the car is moving forward.
These are the pins on the servo motor itself. This is to test if the servo motor is working.
Old 07-23-12, 10:30 AM
sr20mofo
sr20mofo's Avatar
maybe ur butt warmer is on
syedma
NX - 1st Gen (2015-2021)
05-22-19 03:26 AM
herbSC3RSB
Performance & Maintenance
02-17-12 05:47 AM
SC300-T
02-04-12 04:01 PM
svlexus
03-28-11 07:47 AM
ajcsanders
06-26-06 01:41 PM
Quick Reply: Is it me or is it really hot when AC is off?
