Found Flyaudios Manufacturer
#211
Hey 07awdis250:
So it is an 8" screen right? I found out that this unit has a built in microphone, not like Flyaudio that has one wired and located anywhere you choose. Have you tried making calls on it yet?
Did you have to pay any duty on the shipment since its from China? What version of igo is it, 8 or 9?
Thanks for the pics! Looks like you'll be changing out those vents?
#212
Hey 07awdis250:
#214
I dont know what the hell but my car doesn't want to start . The brake pedal is very stiff has anyone encountered this problem before? It cranks just finw but it does not start. Radio, lights ,windows work as well. Im also able to unluck and lock the car with the control.
#216
As for the unit, please update us on the full functionality of it when possible. Thanks!
#221
It;s kind of odd that when you installed the unit your battery drained. Hope there isn't something wrong with the unit or the install.But based on your earlier post it seems to be pretty much plug and play.
#223
#224
you should always disconnect the battery when installing new electronics, even if its plug and play! i hope you did, if not then you probably drained the battery due to the lights being on too long. i experienced that once when i had my car stored for winter, battery was too low and when i charged it up the car started right up. yours will too.
#225
