Found Flyaudios Manufacturer
#316
The screen shot you posted shows the error when iGo Primo is starting. There is sys.txt file that iGo use which has necessary configuration settings for it load or start up properly. Can you post the contents of that file? Maybe they didn't correctly set it up and we can fix it.
For those of us with FlyAudio unit, we get an error when we receive phone calls over bluetooth. The reason is iGo Primo is capable of handling phone calls over bluetooth and it interferes with FlyAudio's bluetooth. There is a way to disable iGo Primo's bluetooth and I'm trying to figure it out.
[device]
type="Generic_device"
[power]
powermgm_state="1"
skip_suspend_process_all="1"
[Main]
ShowExit=1
[Bluetooth]
;btappl="\SDMMC\PRIMO\BTOnOff.exe"
[interface]
show_exit=1
extra_settings=1
resolution_dir="800_480"
;vga=0
;show_bugreport=1
[3d_config]
disable_roadsign_navigation_mode=1
rotated_roadsigns=1
show_guidance_arrows=1
show_guidance_strip=1
[sound]
csv_voice_enabled=1
use_method=1
queue_length=200
sound_volume=255
voice_volume=255
mute_os_key=1
ding=0
[route]
correctness=90
[warning]
speedcam_enabled=1 ;(0)
speedcam_visualtype=1 ;(1)
speedcam_soundtype=1 ;(1) 1=warn if overspeed 2=approach
speedcam_soundtype_4=2 ;
speedcam_warning=1 ;(0)
;speedcam_check_frc=1
speak_tts_only=1
speedwarn_alt_builtup_based=1 ;(0)
speedwarn_alt_limit=1 ;(0)
speedwarn_alt_tolerance=110 ;(100)
speedwarn_alt_toltype=1 ;(0) alternative tolerance type
speedwarn_tolerance=110 ;(100)
speedwarn_toltype=1 ;(0) absolute or percentage
[debug]
skip_eula=1
enable_roadshadow=1
loop_sim=1
sound_q_length=200
reserve_memory=1835008
cache=262144
experimental_features="1"
[map]
auto_nightmode=1
map_mode="3D"
[tts]
tts_buffer=131072
announce_exit_directions=1
tts_logics=3
priority="HIGH"
always_say_road_names=3
announce_street_name=1
skip_exit_numbers=2
#317
here you go , hope you can fix it.
[device]
[power]
powermgm_state="1"
[Main]
ShowExit=1
[Bluetooth]
[interface]
show_exit=1
extra_settings=1
;vga=0
;show_bugreport=1
[3d_config]
rotated_roadsigns=1
[sound]
csv_voice_enabled=1
use_method=1
queue_length=200
sound_volume=255
voice_volume=255
mute_os_key=1
ding=0
[route]
correctness=90
[warning]
speak_tts_only=1
[debug]
skip_eula=1
enable_roadshadow=1
loop_sim=1
sound_q_length=200
cache=262144
[map]
auto_nightmode=1
map_mode="3D"
[tts]
tts_buffer=131072
tts_logics=3
priority="HIGH"
skip_exit_numbers=2
[device]
[power]
powermgm_state="1"
[Main]
ShowExit=1
[Bluetooth]
[interface]
show_exit=1
extra_settings=1
;vga=0
;show_bugreport=1
[3d_config]
rotated_roadsigns=1
[sound]
csv_voice_enabled=1
use_method=1
queue_length=200
sound_volume=255
voice_volume=255
mute_os_key=1
ding=0
[route]
correctness=90
[warning]
speak_tts_only=1
[debug]
skip_eula=1
enable_roadshadow=1
loop_sim=1
sound_q_length=200
cache=262144
[map]
auto_nightmode=1
map_mode="3D"
[tts]
tts_buffer=131072
tts_logics=3
priority="HIGH"
skip_exit_numbers=2
I cannot guaranty these changes will solve your problems, but if you want you can give it a try. Make sure to back up your entire iGo Primo folder before applying these changes.
[device]
[folders]
app="SDMEM/PRIMO"
content=SDMEM/PRIMO/content
[power]
powermgm_state="1"
[Main]
ShowExit=1
[Bluetooth]
[interface]
show_exit=1
extra_settings=1
;resolution_dir="800_480"
;vga=0
;show_bugreport=1
[3d_config]
rotated_roadsigns=1
[rawdisplay]
screen_x=800
screen_y=480
[sound]
csv_voice_enabled=1
use_method=1
queue_length=200
sound_volume=255
voice_volume=255
mute_os_key=1
ding=0
[route]
correctness=90
[warning]
speak_tts_only=1
[debug]
skip_eula=1
enable_roadshadow=1
loop_sim=1
sound_q_length=200
cache=262144
[map]
auto_nightmode=1
map_mode="3D"
;[gps]
;port=6
;baud=4800
[tts]
tts_buffer=131072
tts_logics=3
priority="HIGH"
skip_exit_numbers=2
#318
NimaM,
I tried the the new definitions you added and they didnt work. I managed to do
A hard reset on the unit and install the original sd card and configure it again and
Now it works. I hope it keeps working and does not give me any errors. NimaM,
Thank you for helping.
![](http://i523.photobucket.com/albums/w355/stikiller2189/482afd9d.jpg)
![](http://i523.photobucket.com/albums/w355/stikiller2189/14b983f1.jpg)
#323
07awdis250, do you have any pictures of it during the day ?. Just wondering how the color of the new nav unit match's the oem cd changer color ?.
Anyone know if they have a specific 06-08 model ?. This way I don't have to replace the vents.
#325
I spent some time chatting with the girl from szlsqstar
(http://szlsqstar.en.alibaba.com/prod...vd_player.html).
I got the following price:
Unit = $480
SD Card (US Maps) = $10
Shipping = $ 68
Total = $558
Not sure if somebody else from south florida wants the unit as well.
If so, we could probably buy together and save on shipping.
I tried to get as much information as possible about the temperature, and according to her, she is checking with her engineers.
07awdis250 - In case she comes back with a solution I'll update you.
07awdis250 - I have one last question about the unit. Do the wheel controls fully work with the unit?
Unit = $480
Shipping = $ 68
Total = $558
#326
I have a MY2012 IS250 that is about 3k miles without NAV. I can confirm that the color for the top part of the console, DOES NOT match the color of the CD changer. Very slight difference, but it is there. I suspect that difference will only intensify over time.
#327
Unit = $480
Shipping = $ 68
Total = $558
Unit = $480
Shipping = $ 68
Total = $558
#330
looking good so far guys! vents will complete the look, and i have to say that igo primo 9 is the best nav software i have used so far. i really like all the options it has like the mp3 player, and the buildings it shows when im downtown. the night settings are cool too, but the best one is the overhead signs displays, just the the ones you see when on the xpressway, and the exit offramp splits. im still waiting for a RMA number so i can exchange my unit or get it repaired by fly audio. i love my unit and use it everyday, espically the dvd feature and usb., but the freezing and changing on its own is what makes it a pos unit.
