Found Flyaudios Manufacturer
#346
the china unit has a black cable which in one end connects to the back of the unit and the other end has all the ouputs look at the picture in the link below so you can see what i mean, there is no ouput in the back of the unit all are located at the end of the balck cable.
http://www.alibaba.com/product-gs/51...0_car_dvd.html
#349
#350
Here up North we already use Celcius. You can thank Reagan for not implementing the metric system in the US, agains ISO recommendations.
#352
Celcius wouldn't be a problem in my case.
I live in South Florida, but I'm originally from Brazil, and there we use the Metric System.
But I'm still a little afraid to order the chinese unit.
First, the Radio issue (radio stations are off by 3 to 4 mhz).
Second, the camera from 07awdis250 stopped working.
I talked to the seller over skype, and they did not show much confidence and knowledge about the unit.
Basic question regarding the Temperature, Bluetooth, Radio, couldn't be answered.
Besides the use of google translation (some of the stuff that they wrote did not make any sense)
I guess buying this unit means no support, no updates.
Almost "as is"
Almost "as is"
#353
Almost "as is"
Almost "as is"
#354
...I talked to the seller over skype, and they did not show much confidence and knowledge about the unit.
Almost "as is"
Almost "as is"
#355
i know what u are saying, but you mentioned that your camera was plugged into an output . on my fly audio unit it had a yellow female rca connector labled " rear camera in" so my question is does your unit have a rear cam input rca or not, maby your unit has no dedicated input for the camera?
#356
I find it funny that you guys keep saying the C/F is an "issue" that needs to be "fixed". That implies that it's broken/defective/not functioning properly. It's working just fine though you just don't understand Celsius.
#359
#360
i cant see how trying a different camera will solve the issue, a video signal is a video signal period. try plugging in a portable dvd with video out into that source where the cam was and see if you get an image to show up, and dont forget to give the reverse wire 12v
