Found Flyaudios Manufacturer
Old 08-29-12, 08:08 PM
  #376
knbnguyen
knbnguyen's Avatar
https://www.youtube.com/watch?v=vDAU...A&feature=plcp
here's the link for open box of the unit.
Old 08-30-12, 03:13 PM
  #377
nosurprise
nosurprise's Avatar
Originally Posted by knbnguyen
Yes i did, everything work great, but the USB connector is not the same.... you can't just plug in the usb .. it look like it is a male connector inside. HOwever, i went out and buy a female connector and it still doesn't work. After further exam, i see that the pin inside is a bit different. it like this [ I I I I ] and for the our normal usb.. it is like [ I I I I ]. After i talked with their rep, they said lexus have it own cable in the back. I google 2010+ IS350 and indeed they have a factory USB connection in the arm rest ... so, did lexus have their own connector behide the 2010+ unit???
Where did you order one that works with IS350? It works except the USB? What does the USB plug looks like?
Old 08-30-12, 03:44 PM
  #378
knbnguyen
knbnguyen's Avatar
well, i got it to work lol... i just cut the original cable up and rewire it with the normal usb plug and it work perfectly LOL
Old 08-30-12, 04:14 PM
  #379
skullkandy
skullkandy's Avatar
^ that sounds ghetto as!
Old 09-01-12, 08:17 PM
  #380
getmet
getmet's Avatar
can i put my old clock in the fly audio version? does it fit? Also, does flyaudio lag at all???
Old 09-06-12, 08:44 AM
  #381
xpionage2
xpionage2's Avatar
Can someone please confirm if it's possible to use an aftermarket navi head unit to replace a defective OEM navi unit?
Old 09-06-12, 08:54 AM
  #382
xpionage2
xpionage2's Avatar
I just installed the Chinese unit in my 2011. That black wire that comes out of the back of the unit is supposed to the factory isb harness. I think only MY2010+ has this option. Previous years may have to do it the ghetto way like you did. The connection is made by the shifter, under the center console.
Every thing is working great, but radio stations. Just like others here, the numbers are way off. For about $750 savings compared to FA, I say it's a good trade off.
Old 09-06-12, 09:40 AM
  #383
My0gr81
My0gr81's Avatar
I see you installed this unit. What did you do with your stock nav unit?
Old 09-06-12, 09:43 AM
  #384
xpionage2
xpionage2's Avatar
i didn't have the stock nav unit. It was just a general question for existing oem units and if they can be replaced....
Old 09-06-12, 11:31 PM
  #385
Xao604
Xao604's Avatar
for those of you who installed this unit, where did you leave the GPS receiver? was it behind the unit or did you place it somewhere else in the car?
Thank YOu
For those who are interested i bought the bonroad unit with the new 3g. it was delivered in a fast 4 days.
Old 09-07-12, 02:24 AM
  #386
johnchi
johnchi's Avatar
Thank YOu
I put mine in the location of the ML speaker - top of the dashboard. Its hidden and picks up sattelites great.
Old 09-07-12, 03:42 AM
  #387
linus73
linus73's Avatar
yes it is possible to do it because i did. nothing was wrong with my oem navi, i just wanted the flyaudio unit because of the dvd and usb features. although it is possible it will require some modding of 1 harness and adding an rca connector to the factory wiring to get the rear camera to work without running wires or replacing the factory cam. you probably will not find anyone on here other than me and one other person who has done the swap successfully, when i did mine i found some diagrams on here regarding the "adding navi to non navi vehicles" thread and its pretty much just reversing this process and buying a connector and retrofitting 1 harness. also there is a thread that i posted that shows what i did with pics. . i contacted the other member who had done this mod with never a response from him, and i had to figure it out by myself. so now im giving back so others with oem nav have an option if thier oem nav unit goes bad. if your not familiar with car audio and wiring, dont atempt this mod as you may cause some damage, always have a fellow CL member /buddy help you if he is experienced or take it to a car audio specialist.
edit: here is the thread and files
https://www.clublexus.com/forums/is-...s-of-pics.html
https://www.clublexus.com/forums/att...uctions-1-.pdf
Old 09-07-12, 04:39 AM
  #388
knbnguyen
knbnguyen's Avatar
Yeah i kinda figure that, however for a 520 vs 1300... i think it worth every penny.
Old 09-07-12, 04:49 AM
  #389
My0gr81
My0gr81's Avatar
Thank YOu
Can you please provide a link with pricing? Thanks
I looked them up and only found an ES350 unit on their website.
Old 09-07-12, 07:36 AM
  #390
rockopico
rockopico's Avatar
here's a link:
http://www.alibaba.com/product-gs/54..._Lexus_IS.html
I still haven't figured out how to really replace the vents though if you have an '08 or older IS250. The clips are different. Sounds like you have to jerry-rig it or something.
If anyone can provide details on how to actually replace the '06-'08 center vent with the newer style, I would appreciate it very much. I'm sitting on this unit because I haven't figure out exactly how to change those vents without having to modify something.
Quick Reply: Found Flyaudios Manufacturer
