Found Flyaudios Manufacturer
#406
yes i paid them directly thru paypal.
So after using the GPS navi for a while. I got IGO primo working perfectly but i find that for some odd reason when i go to NAVI it goes automatically to AUX mode and music stops playing. is it suppose to be doing this or did i wire it wrong and i find it sort of odd when i have to go to cd changer again...
#407
I'll get it then ... I was planning to get a bluetooth module only for calls, but that come out to $200 so might as well just get this. How's the bluetooth calling quality? I heard some people complain about it; does it use the mic on the phone? Can an external mic attach to the unit?
I read about this AUX mode changing problem somewhere (not sure if it's specific to NAVI), and the fix was unplug the AUX cable.
#408
I'll get it then ... I was planning to get a bluetooth module only for calls, but that come out to $200 so might as well just get this. How's the bluetooth calling quality? I heard some people complain about it; does it use the mic on the phone? Can an external mic attach to the unit?.
#409
I think there was mention of a diagram regarding hooking up a reverse camera? I installed the Roadrover I got from Alibaba ($580) shipped, and everything works. Same issues about clock, etc, but the unit is a deal compared to F/A, I think. Can anyone help with back-up camera hookup? Thanks.
To simplify a little of the diagram, once you remove your trunk liner:
-Reverse cable (behind the unit) and Red cable (12v+) needs to be connected to the reverse light YELLOW CABLE.
-Black cable (12v-) needs to be connected to the WHITE CABLE with BLACK STRIPES.
#410
J250, thank you very much. As soon as I run the cable thru the car, I'll check this out. I too have the "aux" problem when I go to "NAV". The aux comes on and I can't play cd's or ipod. Does anyone know which is the "aux" cable behind the unit? I've already taken this thing out twice, but maybe the 3rd time is a charm. Thanks.
#411
I installed igo primo and I like it much better.
#412
Is this "aux" problem happening to the LSQ Star units only? I ordered it from Elaine and the only major issue I'm having is the radio stations. The specifications do call for RDS feature though, but I don't think it has it?
#413
#414
what cables from the unit are not needed to be connected from the harness like the rca cables if you are not connecting a back up camera and what about the other pink wire, I believe the other pink wire that says brake needs to be grounded to play dvd while driving? does it have a built in mic for usb? thanks
#415
IF you really wish to keep the IGO8, the only method i can think of is, go into the IGO8 folder into the TIMEZONE file. In Word Pad, change all the timezones exactly the same as Pacific Standard Time forcing it to be the correct time. Do not delete all the timezones and leaving PST only as this will cause an error in the navigation. PLEASE remember to back up the entire IGO8 files into a separate SD CARD because anything that changes MAY effect the entire navigation.
As i mentioned in previous post, IGO8 is known to cause issue on the system it is running on. Systems such as Android which forces the entire cell phone's time to follow the IGO8 GPS satellite time. There are solutions for the Androids which I tried on our unit but was not successful..
#416
#417
#418
The unit I got from alibaba (roadrover) already had igo primo. At least that's what the screen says when it is initializing. Also, wondering if anyone can help: the pink "brake" wire that comes with the new harness, that needs to be grounded; is there a specific wire I can use in the car in the recess for the nav unit to hook up the pink wire to ground it? I don't have electrical test equipment, and I don't want to screw things up in there. I'm trying to get my dvd option to show the reverse camera image. J250, thanks for the pics, they will definitely help when I get to hooking up the reverse camera.
#419
#420
4LisaJean: use a spade terminal and connect the "brake" wire to the headunit's side metal bracket. I just used one of the existing screws. The black chord is supposed to connect to the factory USB harness in the center console if you have one. If you don't have a factory USB then I think you actually have to cut and modify it to work with a standard USB cable like how one of the other members described in a previous post.
