Found Flyaudios Manufacturer
#556
My non fly navi came today it has no name brand on it so idk what to call it but w/e lol cars at dealer getting fixed so cant put it in till i get it back
. i got the OE style back up cam and it looks good cant wait to put it in. it replaces the plate LED light with cam+LED light.
[/IMG]
![](http://i1124.photobucket.com/albums/l579/dgny2009/20121116_124534.jpg)
#557
How are you planning to take the license light out? can you post some pictures or instructions when done?
I just ordered the 09 vents. If you look at the colors it seems to match it better as the side vents are also black.
I'll post some pics when complete. It takes more time than I expected to tweak :/
If anyone can post pictures that explain what modification you need to do to get the '09 vents to work with an '07, that would be cool.
#558
What did you use instead of this cam? do you have a pics of this cam installed on the car?
Looks better then this IMO lol
![](http://www.azentek.com/smartmirror/VTL421.jpg)
#559
yeah, that's what I think ... it might be a good way that you don't have to drill a hole into the car; might not be that bad once recess into the light, not sure.
they all say remove the clips from the bottom of the new vent ... I assume that would work, I haven't got my vent yet.
#560
Hi, everyone. I installed the same unit as dgny2009 . I have trouble making the reverse camera work. I followed all the instruction that the girl Kathy from bonroad who sell the unit to me. Here are the following instructions
1. Tap the reverse power from your reverse light
2. Plug the yellow video cable to the back of the radio with ccd in
3. I tried to connect the remote line of the yellow cable with red wire by tapping it to the positive reverse light, and the other end tapping it at the back of the radio with ccd+12v
4. At the back go the radio I also wired the blue wire to the positive line of the reverse light.
After I done all things that I was asked to tap. I tried put it in reverse but the camera doesn't activate.
I hope anyone in the thread could show us their DIY or wiring diagram for installing reverse camera for road rover.
#561
Does anyone know on how to change this plug to female USB plug? Or does anybody know which adaptor I need to buy to convert it to female USB ?
https://www.clublexus.com/forums/att...1&d=1353226421
#562
Sharing you the pics of the wiring for road rover radio. I hope there are some member who could enlighten us, road rover user on how to install this following wires on the right places.
#563
#564
If you want to locate parts, they might be on an 09-10 year car; though I won't know which it would be. http://is.sewellparts.com/oem-catalo...S350-2009.html
#565
A few pages back someone just cut the wires and match it up to a female USB (actually he did it weird; he matched up to a male USB and connect another female-female plug
), but didn't post any wire colors. I think you need to test it with a multimeter to see which wire is which -- it probably matches up like a regular USB.
#566
lol, ok, thanks!
That probably won't work on our unit as it still uses the older user interface ... if you could wait, maybe wait for them to update the software, but not sure how long that takes.
Yes, I installed it on my 350, and it works fine -- I need to check if the smog sensor is adjustable, but I think it's not. For the Aux cable, I didn't do anything to it and it functions like factory. DVD, I didn't do it yet, it's wired labeled "Brake". I put my antenna on top of the blue box attached to the stereo (anyone know what that is?), some people put it inside the center speaker holder that's empty.
I found this pretty nice app that can let you customize the UI ..... I really want to do my self but i don't have any software knowledge ... it will be really cool if someone could make it to look exactly like the flyaudio UI
Has anyone installed one of these units on an IS350? I thought it would be the same, but the people at LSQ Star told me the unit is not suitable for my car?
I’m very interested in this unit, and if it does work on my 2006 IS 350 I would definitely buy.
I also just wanted to get confirmation on a few points from some of the stuff I read so far:
1) Vents need to be changed
2) Aux cable should be left unplugged to ensure unit functions properly
3) USB cable will not work, unless modified
4) Run IGO Primo or 9 for optimal results
5) DVD cable needs to be grounded in order to watch DVDs while car is in motion – does anyone have a DIY for this?
6) Antenna placement?
Other considerations?
#567
So far after 3 months of using this unit i have to say it worth every penny!!! The only complaint i have is that it could use a little more memory so the system would run smoother...
#569
For those that cant play dvd. All you got to do is use the brake label wire and connect it to the metal side of the bracket that hold the unit in place. For the gps antenna, I wire it around and mount it on top next to the rear view mirrir holder. Never have any reception problem.
#570
I also took a picture of the new vents if anyone can point out which part to clip off -- I posted this on another thread about fitment as well ...
![](https://www.clublexus.com/forums/attachments/is-second-generation/263810d1353350203-non-flyaudio-navigation-system-center-vents-fitment-imgp3347.jpg)
