Found Flyaudios Manufacturer
#602
That may be to far in the car for it to get signal lots of things in there blocking it.
put mine under that cover in the center on the dash on top had to make a metal bracket for the hole in the middle of it and shave the inside of the cover some but i get grate signal. and its hidden.
#603
#604
Put the gps receiver on top of the tire sensor, which is on top of the unit itself. Just pull the vents out and put the GPS antenna on that box (which is on the left side of the nav unit once you pull the vent out). no modification required to do this. I get a great signal.
Part of the problem with this unit is that some people have to mess with the sys.txt file on the SD card that came with the unit in order to get the GPS to work (that file is in the "Primo" folder on the SD card).
I had to change the port and baud settings to auto...the GPS wouldn't work until I started jacking with the files.
#606
You can play mp3 or movies off that USB? Impossible.
Anyway, if you have that USB port, then you have a factory harness that connects to the black cable from the china navi. That's how you watch movies or access files from a USB stick.
#607
where do I find the factory harness? because I did not have to unplug anything out of the original radio that fits into the black usb wire
#608
The reason your USB works is because it's using your original factory CD Changer to play the sound. It won't work with the new unit to play movies or show things on the screen until you plug in the USB cable that comes with the new unit. The outlet is probably under where your factory USB plug is.
Or you can cut the new USB cable and fit it with a regular USB plug then you can have 2 USB plugs !!![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
It appears only the passenger airbag light doesn't work (they probably gone cheap and didn't put one in at all -- like the clock). I got it from here. http://szlsqstar.en.alibaba.com/prod...vd_player.html
#609
I will probably buy from bonroad Eelanie it was here on the forum
#610
Hi
I do not want to sound too stupid but the sd(micro) on my unit has only the navigation iGO primo files on it but to change the original picture I would have to go into the WinCE root how do I do that with SD card or even a USB connection to my laptop?
Thank you for your time.
Sudip
Sudip
#611
Placed my gps receiver on the dash to see if that caused any reception issue but till can't get any lock to satellites although I have red bars which are lit up.
My unit came without an SD card, can anybody tell me what primo they are running successfully and what values you have in the sys.txt file under gps (baud and port) settings?
#612
after letting it run for 20 minutes with the gps receiver on the dash and the correct port and baud rate I've picked up maximum 3 or 4 satellites, most of the time 2 satellites. Not really enough to have a smooth connection. Did anyone have this issue as well? should i try to install the gps receiver under the hood to solve this , or buy a better gps receiver? I have no problem with my tomtom or iphone gps
#613
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
#614
All right and somebody got into a cover Windows or other navigator established, at the Russian forum there is a lot of information on reinsertions of installation of any programs, but I can't understand everything isn't clearly written
#615
It has all the information to install the navigation system. Download it on to an SD card and then you will have to go to the system to select the exe. file rest follow on screen instruction. That should most likely resolve your issue with satellites. Keep the sys.txt file the way it is in the download. It works most of the time.
