Found Flyaudios Manufacturer
#721
You don't have to connect anything to the video input cables (RCA connectors).
You can leave the ILL cable as it is. If you ground the Brake cable you'll be able to watch DVDs while driving.
#722
OK. so i don't even have to plug that black power cable in at all that is attached to all those RCA cables?
and so the cable that has the "brake" it just plugs into the smaller rectangle square that is on the back of the unit? what about the other two connections?
and the bottom 3 cables are they plugged in the right slot? im still unclear why i have no picture on the dvd screen? is there a specific cable i need to plug in to get picture on my screen?
#723
I have a few questions, I'm trying to get my navigation installed.
1. For the first picture I was wondering if I'll need to be using those wires? if so will I be using every single wire? or just only a few that's in there
2. For the second picture, will I be using all 3 of the wires? or am I just using the brake wire? Also where am I suppose to ground the wire to?
Thank you!
Thank you!
#724
Thank you!
Thank you!
#727
My bad the it wasn't the ccd wire it was the blue reverve wire and the CCD rca wire thats were you connect the video signal from the back up camera. For the ground I found a bracket behind the dash. That black box behind the radio every car has one. I don't really know what's the function but your has to have it. you will see it when you remove your stock radio.
#731
Does anyone have a link where i can download the US maps for IGO primo 2.0? My SD card only came with the Canadian maps and i need the US ones as well. if there is someone that wants the Canadian maps i can upload those files somewhere on the web if you can help me with the US ones. The map files are about 400 MB.
Also, Is there a way to install the maps right on the system, or do i always have to always keep the SD card with the map in the SD slot?
#733
try this website http://**************.com/forum/forum.php
i installed a black silver theme on my igo 9
#734
How is IGO 9? is it much better than PRIMO? whats the difference? i want the one that shows all the buildings, so far i haven't see any on my screen...
#735
