Found Flyaudios Manufacturer
#736
#739
Has anyone had issues with the unit freezing?
I was doing a bit of multi tasking today running the GPS and playing music and switching to a DVD. I'm not sure if doing all this caused the unit to freeze or If it was some other issue.
#746
Yea cut the plastic clips that are shaded red on the picture. There are three little plastic dividers\walls located between the clips, I circled them in red. You have to have to cut them out until the cd change sit flush on the radio.
#748
can someone help me out. i am confused how to hook up this plug and play unit. specifically, where am i supposed to hook up all those cables labeled V-OUT 1, V-IN 1, R-IN, L-IN.
and what about that cable that has the "brake" and "ILL" wires attached to it?
Can someone tell me what im doing wrong. i can get sound from my player but no picture on the dvd unit.
![](http://i1124.photobucket.com/albums/l580/jtwenger/photonav2_zpsec17bd75.jpg)
![](http://i1124.photobucket.com/albums/l580/jtwenger/photonav_zpscd75731b.jpg)
![](http://i1124.photobucket.com/albums/l580/jtwenger/photonav3_zps5ab1f74b.jpg)
#750
I installed the navigation today, Plug everything in and what not, and when I plug the power source from the car to the navigation, and I checked it to see if everything was working, I notice that the navigation screen had no pictures or any of the buttons working, the only button that was working for me was the emergency lights that worked and everything else wasnt, I don't know if my system is defective or not, but would anyone know what I should do or what I did wrong? Also when I switch wires to my non nav, all the buttons worked. Thank you.
